Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
No display, No beeps, No heat
My Jenn air double wall oven stopped working. The oven light comes on when I open the doors so I assume the power supply is not the problem.The display is totally blank,not just dim. No beeps.No heat.Is there a fuse somewhere internally? How do I remove the display panel?
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Posted on Jul 17, 2008
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Feb 15, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
434 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
