Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Possible to change default scan setting to PDF?
Is it possible to change the default scan setting from JPG to PDF? Nobody in our office scans to JPGs, yet that is the default setting. Is there anyway to change the default so it automatically scans to PDF, instead of having to go into the scan settings menu every time we scan?
  • Anonymous Mar 05, 2009
    Hi Kevin
    Any ideas which page on the web browser this would be?
    Problem Solver:
  • 12 Answers
Go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Posted on Jul 28, 2008
  • 167 Answers
Go into the utility screen, log in under administrator mode and there you will find scan settings.
Even better is to log in via the Web Portal, type in ther IP address of the machine in your browser.
Once the page comes up, select "log out" and then re-log-in as the Admin. From there you can also set the default file type. It is quite a bit easier than trying to navigate the menus from the panel.
Posted on Jul 18, 2008
Canon SD1400IS is taking three pictures (jpgs) of every shot. I only want one jpg
Have you tried resetting the camera back to the default settings? See page 50 of the owner's manual. (http://www.canoncompact.com/manuals/sd1400-manual.pdf)
Mar 08, 2012 | Canon Cameras
I need to scan documents in jpg format. I notice there is an option to choose tif/jpg but I don't seem to be able to choose the jpg option it just keeps choosing tif. How can I scan in...
Everyone above has cut and pasted from the Ricoh manual, which as any tech will tell you is worthless. There is some other setting that must be set to force the "TIFF/JPG" to toggle - hence why no one has figured it out.
Jun 17, 2011 | Ricoh Office Equipment & Supplies
How to scan documents and save them as jpg Format as default instead of tiff?
On some copiers, there is an option to scan as JPG. Press the Scanner function key on the left, and look for a button on the screen that says something like "Scan as file type." Press this button, and if that copier can scan JPG files, you should see the option there. Otherwise you might have to scan as TIFF files and then use a program like Microsoft Office Picture Manager to convert them to JPG images.
May 21, 2010 | Ricoh Aficio 1035 Copier
Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Mar 31, 2009 | Minolta Di3510f Bizhub Copier
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
HELLO
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
Jun 22, 2008 | Epson CX8400 All-In-One InkJet Printer
HP 85gxi - How to scan to PDF?
My "work around" is to use a pdf creater like cutepdf (downloadable freeware). I "printed" the scaned JPGs to cutePDF and saved the output pdf. I also learned to specify the output DPI as 150 instead of the default 600 DPI to get the file a little more reasonable size.
It would be nice if it would scan directly to a PDF.
Apr 03, 2008 | Brother MultiFunction Center MFC-440CN...
Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Dec 11, 2007 | Cameras
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,432 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
