Question about Nokia 1600 Cellular Phone
My phone is not ringing on incoming calls
I have nokia 1600... my phone is not ringing on incoming calls, I have tried everything. The ringing vol is full, ringing tone id also set but its not ringing. I have tried even restore. but its worthless....playing ringing tones dont have any problrm but during incoming call its not ringing
  • 2 more comments
  • Anonymous Mar 18, 2014
    always busy tone
  • Anonymous Mar 19, 2014
    When the phone rings, it will not let you answer the call
  • Anonymous Mar 20, 2014
    rings 4 times
  • Anonymous Mar 21, 2014
    no ringing tones for incoming calls
  • 52 Answers
Did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
Nokia 2730 - not getting ring tone with some incoming calls. Message left that I have missed a call
If you are facing the problem with some incoming calls it is an indication that you have set different ring tones for different users or incoming calls.
Very simply reset your mobile to a default setting by going to setting, restore factory setting and every thing shall be back to normal.
Oct 24, 2012 | Nokia 2730 Cell Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Nokia 6800 won't ring
go to profiles settings, then select GENERAL........
sexy-ym
Sep 04, 2008 | Cell Phones
Ring voloume
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
Jul 20, 2008 | Lands Phones
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
Nokia 1600 Cellular Phone Logo
2,218 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
