unplug 4 about a minute, then plug back in this will reset the router as well
SOURCE: Wireless Linksys router won't reset to factory
There should be a tiny hole about the size of a pencil head either on the back or underneath the router. You will need a pen, pencil, or paperclip to press in the hole. That should reset the router.
SOURCE: cannot reset to factory settings
Turn the router off.
Hold the RESET button in, for 30 seconds.
Turn the router on, and see if it has reset.
If not, then with the router still on, hold the RESET button in, for 30 seconds, and see if it has reset.
Note:
Resetting
the router to the factory defaults will delete any changes you have
made to the router, including any security settings. This should be used
as a last resort.
The first method involves simply pressing
a button located on the back of the router. The image below (courtesy
of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
