Question about Ricoh Office Equipment & Supplies
ERROR CODE SC997 COMING UP ON SCANNER. WILL NOT STORE SCANS. Ricoh Aficio 2027sp
  • William Boared Sep 09, 2013
    Turn it off for 30 seconds then turn it back on. Sometimes they need to reboot after a firmware update.
  • 31 Answers
SC997 is an application error that seems to like to show itself on occasion, it's not considered serious. It tends to show up when scanning, and it basically means the copier couldn't do what you just asked it too. A hard power cycle clears it and in many cases it doesn't come back. I would ask your tech the next time he's out to update the firmware. The problem with that though is that your particular model uses the older flash cards to flash firmware and most techs don't have them or know how to use them.
Posted on Jun 18, 2009
  • 304 Answers
That is the software defective code. I would recommend going to the manufacturers site and downloading the latest software for your scanner/printer. Remove the old software through add/remove programs then install the new software and you should be good to go. Hope this helps you....
George
Posted on Jul 15, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    This is the link to download and install all new drivers and software you need. Just select your make and model and operating system and dowload and install the new drivers.
    http://www.ricoh-usa.com/downloads/softw...
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
  • faatmaan Jan 21, 2014
    format hdd
    New Friend:
How to use install and use fax for mpc 4500
Posted on Feb 06, 2014
  • mohamed_engn
    mohamed_engn Feb 06, 2014
    how to use install and use fax for mpc 4500
    i can not change the ip for richo mpc 4500
  • mohamed_engn
Resolve a J011 error - paper jam
Firstly clear the paper jam then reset the printer!
Oct 13, 2014 | PrintCountry Ricoh Aficio 2027SP Laser...
Sc997
Application function selection error
The application selected by a key press
on operation panel does not start or
ends abnormally.
• Download the firmware for the
application that failed
• An option required by the application
(RAM, DIMM, board) is not installed
Re-seat the RAM on the controller board
Mar 28, 2013 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh afi 1022cio error code 101 need reset thank
Exposure Lamp Error
Symptom: The standard while level was not detected properly when scanning the white plate.
Possible Cause: • Exposure lamp defective
• Exposure lamp stabilizer defective
• Exposure lamp connector defective
• Dirty scanner mirror or scanner mirror
out of position
• SBU board defective
• SBU connector defective
• Lens block out of position
• Incorrect position or width of white
plate scanning (? SP4-015)
Jan 17, 2011 | Ricoh Aficio 1022 All-In-One Laser Printer
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
16,049 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
