Question about GE GSS20IEP Side by Side Refrigerator
Freezes ice, but food compartment is not cold enough, have cleaned and left unplugged overnite, did not fix problem. HELP
Have cleaned and left unplugged overnite, did not fix problem. HELP
Sounds like fan is running, but could there be a blockage in getting cold air to food compartment?
  • C Ruby Jul 16, 2008
    Thanks to ALL, there was a cardboard piece of paper stuck in fan! AND, by shutting off it defrosted blockage in line so water is going into drip pan. YEH
    THANKS AGAIN!!!!
THE DEFROST HEATER IS PROBABLY BURNT OUT // NEEDS REPLACED MOST REFRIGERATORS HAVE TWO.
Posted on Jul 15, 2008
  • 4,889 Answers
Yes. You got it right You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
  • eagle338
    eagle338 Jul 16, 2008
    Look for some kind of blockage apart from ice. I had remove "A HAIR BALL" from a fridge that had a problem like this recently. I was still not able to figure out how it got in there..!!
Rge 400 fridge freezer purchased 2011
try moving the temp prob down on coils inside or let hang if same unplug thermistor in back let run overnite if ok replace thermistor
Jun 16, 2014 | Dometic Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer compartment freezes okay to at least -5 degrees fridge will not cool below 17 degrees
Typically, the fridge gets its cool air via a vent from the freezer. If this vent becomes blocked, then the fridge won't cool. If there is nothing obvious blocking the vent (like a plastic bag) on either side then it is possible the vent is clogged with ice. To fix this, move your food to a cooler and unplug the fridge long enough for the ice to melt (12-24 hours).
Mar 03, 2011 | Refrigerators
Water pressure is at a trickle in door dispenser on fridge. filter is clean and mounted properly.
Check the water reservoir in the rear of the fresh food compartment. It may be frozen. If so, there may be an issue with the "damper control assembly" (located in the upper left side of the fresh food compartment) that allows cold air from the freezer compartment into the fresh food compartment. This cold air works its way down to the reservoir (and perhaps other items) and freezes the water inside the reservoir, which disallows regular flow of water at your external dispenser.
Contact an appliance service company.
Feb 19, 2010 | Frigidaire FRS26H5AS Side by Side...
Fridg is not working right
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Freezer not cold enough, frig ok Frigidaire FRS6LR5EM7
Your defrost element is probably faulty, this is in the freezer compartment at the back and behind a removeable panel. You should change both the element and the defrost limiting thermodisc at the same time.
Mar 03, 2009 | Refrigerators
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
91 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
