Question about Bosch Washing Machines
The maxium spin is so noisy it can not be used.
  • 41 Answers
Drum bearing failure if it makes a rumbling sound like a jet taking off
Posted on Jul 15, 2008
Water has been leaking out of the bottom of my washer, and it has been making a horrible grinding sound. It finally stopped spinning last night, though it makes noises and tries to run.
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
During spinning it is really noisy now. works
you should never use bleach in any machine as it will damage your machine beond repair.and yes i think your spot on the main bearing is gone and needs replaced.adrian,,,,
Jun 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
No spin & drum is very noisy during cycle ,like a jet engine
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
Mar 15, 2009 | Washing Machines
Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Oct 13, 2008 | Hotpoint WMA76 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
