External hard drive not openning
I have a lacie external hard drive 250 gb. my computer doesnt open it anymore. i have all my information on it. i used it the other day and i shut down the computer with it connected. it didnt shut down so i ripped it out (i know, i know, badly done) and it proceeded to shut down. now when i connect it, nothing prompts me that it is connected. it doesnt ask me if i want to view files on it nor does it show up in 'my computer'. dont know what to dooo
  • anni_tomich Jul 15, 2008
    thank you veryyyy much, im going to try everything you said. ill let you know if it works!
  • anni_tomich Oct 03, 2008
    dude, i still havent retrieved the info from my harddrive. everyone says they cant. cuz its somehow damaged. they said the only way is to go to those big retrieval centers which cost up to a thousand dollars. i am not doing that.... but im still keeping my lacie just in case. damn lacie
Posted on Oct 03, 2008
  • 304 Answers
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
George
Posted on Jul 15, 2008
My Lacie 250Gb ruged HD doesnt appears anymore on finder (LION ). I tried USB CABLE, FIREWIRE 800 but noithing happened. I tried to conect on a PC too lking on the Devices Manager and nothnig showed up....
It sounds like it has failed. If there is anything important on there take it to a data recovery expert who will charge a lot of money to attempt recovery of information. otherwise put a sledgehammer through it and trash it.
Oct 18, 2017 | LaCie (300728U) 250 GB Hard Drive
My iomega external hdd has its lights on but cant be detected and does not seem to read anymore
i had the same problem. you have to be patient. open my computer through the start menu. unplug the hdd wait 15 secs and plug back in. if it still doesnt read try another port. and if it still doesnt work your hdd has a malfunction and you may need a new one
Feb 01, 2011 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
How do I put my downloaded movies into Lacie hard drive 160
if its on a flash or C drive....... go to my computer open the folder with the movie(s).....go back to start my computer open the external hard drive (where you are going to put the movie)..... now copy and paste or click and drag from (flash or C) to external......what ever software you are using to download the movie(s) you can also change the download location to the external (now you will download directly to external)
Jan 23, 2011 | LaCie (300728U) 250 GB Hard Drive
When turned on LAcie hard disk is noisy, then asks formatting
Please try it on another computer. It seems to be a hardware issue with the drive in case you are hearing a noise coming from it. In case it is under warranty, please get it replaced ASAP.
Apr 29, 2010 | LaCie (300770) 250 GB Hard Drive
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Hard drive thinks it is full
well..those ext drives can get confused..only way to assess this is to open the drive in the finder, and see how large the folders are..
Apr 27, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie drive
I got the same problem mate, im going to a computer store tomorrow and found out what to do , ill email you first thing tomorrow avo when i find out
Mar 22, 2008 | LaCie (300728U) 250 GB Hard Drive
Lacie 250 gb hard drive isn't recognized on computer
Controller got smoked when cable unplugged, take in if ya need the files off.
Nov 04, 2007 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
474 people viewed this question
David Payne
David Payne
