Question about Saeco Vienna De Luxe Espresso Machine
I am housesitting and can not figure out how to use the delonghi espresso, single cup machine. The espresso keeps flowing , even when I turn the knob for steam. Help
    Champion:
  • 279 Answers
The idea is to froth the milk as the espresso is brewing.
Posted on Sep 18, 2009
Delonghi 3500 problem: When coffee starts to come it flows normally for around half cup. After that colour gets bright and it basicly drops water to the cup and coffee tastes mild. No errors in scren
Sound like the filter strainer is clogged:
Try taking out the whole internal coffee plunger assy by doing the following
turn off machine at the machine switch (leave the power point switch on)
Open the door and remove the internal bu pressing the red buttons
Undo the filter plate on top and clean and reinstall...make sure that the assy clicks in correctly
Nov 16, 2016 | DeLonghi Coffee Makers & Espresso Machines
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Coffee espresso machine is delivering too much water when requesting a single or double coffee. the expesso requests seem to be okay.
press the coffee button and hold it until it prepared the coffee.When decide that enough amount of coffee in the cup, run button and the machine will store the new length.
Nov 24, 2013 | DeLonghi Coffee Makers & Espresso Machines
Delongi eam3400 machine. the water flow is good on the back of the machine but drips into the drip tray instead of flowing through coffee grinds/cup?
http://dl.mypdfmanuals.com/new/external_light.php I found the user manual, look in the troubleshooting section Kolbrub
Sep 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
How do you descale the machine,as we have no manual
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
It produces only very small amounts of coffee
If it is an espresso maker, a single shot is only 1.5 onces. I know a lot of the DeLonghi's come with two different size filters for the espresso. If you use the small, you should only expect about that much, if you use the larger it will be about double (still less than a quarter cup). Even though it is very little, espresso is very strong. Either add water to taste for an Americano, or steamed milk for a Latte.
Mar 06, 2011 | DeLonghi Coffee Makers & Espresso Machines
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
DeLonghi EC155 Expresso Maker
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Feb 18, 2009 | DeLonghi EC155 Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
71 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
