Question about Motorola Mobility RAZR V3
Razr v3 flex cable connected but screen is still black
My phone works perfectly except for the display. ALL BLACK! I reconnected the flex cable in the front and back of the phone. What else could this be and can I fix it myself? THANKS SO MUCH!
  • 7 Answers
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Posted on Feb 17, 2010
  • mark52001p Jul 08, 2011
    It has now been over 1 year since I replaced the flex cable inside my motorola v3 cell phone and it is still working as good as new!
  • 1,586 Answers
You'll need a new phone. RAZRs die a lot, and they start their final journey this way - with smaller malfunctions that end up leading to death. Move your contacts to the SIM card if you get the phone to function again, and go get a new one soon. This one's on the way out.
Posted on Aug 13, 2008
Phone is working but the screen is black
squeezed lower left side of display and powered up ,problem fixed
Sep 12, 2010 | Motorola Mobility RAZR V3
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Black screen on RAZR V3
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Motorola Mobility RAZR V3
My screen display no longer lights up--completelly black! Phone still can accept a message. Don't understand how to get the lighted screen back!
Since it is a flip phone i guess your flex is damaged or your screen is faulty.You need to first change the flex or check whether the cord is well connected.
Apr 26, 2010 | Motorola Mobility RAZR V3
Lg chocolate phone screen went black
there is nothing wrong with your phone screen. The problem is from the flex that connects the screen to the phone board.
Its either the flex has worn out or it has loosed contact from inside and that's why thete is no display.
Therefore, check the flex.
Take care.
Mar 10, 2010 | Motorola Mobility RAZR V3
The phone works, recieves and makes calls but both screens are dead???? verizon motorola razr v3
How about the buttons next to the screen? If you do not hear anything when you press those buttons, it is going to be the flex cable. The flex cable connects the phone between the hinge. It connects the 2 displays (it's really one display part with both screens, it has a screen on the front and back).
Basically you have the most common problem with the RAZR, the screen part connects to the bottom via the flex cable and is partially damaged or has ben severed. Not terribly hard to fix but you would need someone who can take it apart and who can get the part as well.
Oct 23, 2009 | Motorola Mobility RAZR V3
Phone displays is not working.
hi
most common problem is lost contact in you flex connector or defective flex connector. try opening your phone and check the connection.
if everything if fine, then your LCD must be defective. have it replace and im sure your prob is solved.
Oct 15, 2007 | Motorola Mobility RAZR V3
Blank Screens
try reflash the phone or replacing the lcd
Sep 12, 2007 | Motorola Mobility RAZR V3
Screen won't turn on
It's very possible that your phone's flex cable is either broken or disconnected from the screen.The flex cable would have to be replaced or reconnected. The reconnection is not too bad but replacing the flex cable is a way bit tedious.I'll choose the first option to see if this works. You'll have to take this to a qualified phone repair shop. These phones are very technical to work on even for someone who knows about them. SAM !
Jun 22, 2007 | Motorola Mobility RAZR V3
Help for mobiles Razr V3
Try master reset under "settings". Sometimes if there is any trama to the phone the flex cable connection to the camera does pop out. If the phone is under a year old and there is no physical damage send it back to motorola thru your phone service. If not crack it open and check the connection. Manuals can be fould online. Its very tight inside this phone so if you think it is very important to get the camera working give it a try.
Jun 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
569 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
