Question about Compaq iPAQ H3955 Pocket PC
Compaq 3955 The pocket PC slides into a case that covers the screen. The rubber that connects the case and the unit have rotted to the point of breaking. Where can I get a replacement? The speaker no longer works. I can listen to music and my notes using a earphone. Would like to get the speaker back. Any suggestions? Thanks Art
  • Compaq Master
  • 13,433 Answers
Thats a good PDA, I had the 3950 model 3-4 years ago
http://www.ipaqrepair.co.uk/store.php?cat_id=6&catname='iPAQ%20Parts%203900%20Series'
speaker
http://www.ipaqrepair.co.uk/view_product.php?product=181
If you need a new external case look here
http://www.ipaqrepair.co.uk/store.php?cat_id=76&catname='iPAQ%20Cases%203900%20Series'
you can also look for the parts on ebay http://www.ebay.com/
for cheaper deals.
Posted on Jul 15, 2008
How to replace cq57-229wm screen
HI,
On amazon you can purchase display for affordable price
Amazon com cq57 229wm screen. Take a look, but be awero... read reviews first.
regards
Mark
Jan 31, 2012 | Compaq Presario, Compaq EVO, Compaq...
How do I replace a power supply in a hp compaq d530 desktop? From the front, behind, top, or bottom?
the top cover should slide off from the back end remove any swrews at back before sliding cover
Mar 05, 2011 | HP Compaq d530 SFF PC Desktop
What is the diff between hp h5550 and thwe compaq
Both are good the hp is more expensive than the 3955 if you are not the type that will use all available facilities , just go for the less expensive.
Nov 18, 2009 | Compaq iPAQ H3955 Pocket PC
SD card not recognized on ipaq 3955
your machine's scan disk drive could be getting old and not work i think your best bet is to buy a new one or replace it.
Feb 26, 2009 | Compaq iPAQ H3970 Pocket PC
Broken screen
Might be easier to swap hard disks rather than screens. Usually, Connect to PC indicates a faulty hard disk.
This can be checked as follows:
Connect HDD player to mains adaptor and plug in.
Connect to PC.
As player starts up, press and hold "Power On" and "Vol +" at the same time until screen goes blank.
Quickly press and hold "Vol -" until PC recognises player as a removable drive.
If the player shows up and allows access as a removable drive (E: F: G: H:.... etc) then the drive is ok, and the unit probably has a corrupt firmware, which can be corrected.
If the player shows as a removable drive but you get an error when trying to access it via "My Computer" , then the hard disk is probably faulty.
Back cover removal:
You need to make sure the two black screws either side of the connector have been taken out.
The back panel has clips on both sides.
Volume side - 1 at the bottom, and 1 next to the volume control
Opposite side - 1 at the top and 1 at the bottom.
Try sliding a metal strip ( about 5mm wide) in at these points.
If the strip doesn't slide in, gently lever the casing apart at the corner with a flat blade screwdriver.
Hard Disk Removal: Undo the four screws in the corners of the metal plate, and gently remove the plate and the connector surround. Gently lift out the hard disk by pulling the blue rubber protector upwards on the opposite end to the hard disk connection. Gently pull the hard disk away from the connection by pulling slightly one side at a time. Swap drives and re-assemble.
Dec 15, 2007 | Philips GoGear HDD6330 MP3 Player
EXPANSION PACK WIRELESS PC CARD
You need to install the drivers for it.
Xracer
Oct 31, 2007 | Compaq iPAQ H3955 Pocket PC
Cannot connect 2 wireless router
In my experience this type of thing bodes of a hardware failure...I think ya WiFi module has gone faulty, sorry to say.. In fact the only way to "Troubleshoot" something like this is to replace the unit and see whats what anyway.. perhaps ya can get one on Ebay or the like?
Aug 07, 2007 | SanDisk Connect Low power Wireless Card...
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
Compaq iPAQ H3955 Pocket PC Logo
171 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
