Question about Dishwashers
Kitchenaid dishwasher motor assembly removal
How do I remove pump combo? Motor was getting louder and laboring eventually, shutting down and everything went dead. Fuse on fusebox not blown. Internal fuse replacement needed?
Need answers fast. Tank you Armand
5 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: Kitchenaid dishwasher motor removal
This motor comes as a module. The whole plastic assembly its in is part of the module. It comes out with 3 slide out releases around edge of module underneath.
Posted on Oct 07, 2007
aborcass
  • 2651 Answers
SOURCE: kitchenaid dishwasher kudp01 pump problem
holding the center nut for lack of better word and unscrewing the wash arm, the next piece will require turning clockwise while pulling up on the plastic lock tab holding to up spout for water supply, gives you access ot 5 torx screws, after that theres 2 more torx screws giving you access to the chopper/ impeller area, thats as far as youll be able to go.
Posted on Mar 18, 2008
JigSaw007
  • 157 Answers
SOURCE: KitchenAid dishwasher is dead
yep, u can use an ohmmeter to test a fuse.
I think uve found the problem .
Good work
Cheers
JigSaw
Posted on Aug 23, 2008
  • 84 Answers
SOURCE: Whirlpool 1145xtp dishwasher motor replacement
Remove the bottom panel under the machine and you will see the pump and motor and work it out,IWOULD HOWEVER LIKE TO STRESS THAT IF YOU DO NOT KNOW HOW TO DO THIS RATHER PAY A QUALIFIED TECHNITION TO DO IT AS IF YOU DO IT AND SOMETHING GOES WRONG IT COULD COST YOU MORE AND THE MANUFACTURER WARENTY NORMALLY IS VOID IF A UNQUALIFIED PERSON FITS ANY ELECTRICAL PART,so please to save yourself a possible fortune rather pay a speciallist then pay twice for what could be once.
Posted on Jan 23, 2009
TechBrian
  • 15 Answers
SOURCE: Whirlpool GU2500XTPb1
The sump and motor assembly can be replaced without taking the unit out of the cabinet and with some guidance, a handy person can do it themselves.
Posted on Mar 08, 2009
Kitchenaid Superba dishwasher getting louder in wash cycle
The bearings in the wash motor can wear and cause the machine to get louder, They can be replaced but it depends on the age of the machine if it's worth repairing or not.
Mar 08, 2012 | KitchenAid Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
My kitchenaid KUDI01DL dishwasher began making a lot of noise while running, then subsequently decided not to circulate the water around to wash the dishes. It sounds like the motor is running (maybe) but...
The problem is very likely in the chopper and/or somewhat possible in the impeller. The chopper is replaceable from the front. Disassemble the pump, the chopper will be on its left side under a cover. That cover is kinda tricky to remove (remove all torx screws you can find, push the thingy on the top of cover with flat screwdriver to the right, slightly pulling it up).
The impeller used to be a replaceable part, and is no longer available separately, so you'd have to replace the whole motor assembly. To get to it - pull dishwasher out and lay it down on its back (or on its side, if there's no water in it)
Chopper
Motor
Mar 29, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
The dishwasher is making a "buzzing" type of noise. I've taken out everything and it's still doing it--seems to be coming from the motor.
You'll need to clean and possibly replace the chopper and/or impeller.To get to the chopper you need to remove all parts you can from the pump assembly inside the dishwasher.
To get to the impeller you'll need to pull the dishwasher out and remove the motor.
Finally, there is still chance that the noise is from the motor itself. Good luck!
Oct 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KUDP02CRBL0 Pump/motor housing removal
yea its a bit of a pip....
but it comes strasight up from the bottom
and then dropped in
watch your seals
Oct 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher makes a high pitch whine when it runs
instead of motor check out the motor impeller that can make the high pitched noise if rusted or cracked. ------------- Motor and pump assembly screw and impellor help....
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Frigidaire seal - impellor remover and install tool
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
Apr 03, 2009 | KitchenAid Dishwashers
My whirlpool du1050xtps3 makes a grindin sound
Yes, this is common. Sounds like bearings in the motor. Will need to replace the pump and motor assembly. 14 6324 -->partimage.aspx?imgid=z3bqljbfahrfmduxntm1oc9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Pump and motor assembly, complete - Original Whirlpool Part. Fits Whirlpool and KitchenAid dishwashers. This dishwasher pump and motor kit comes pre-assembled for easy installation.
Part Number: AP3778061 made by WHIRLPOOL $173.71 In Stock
Order now and it will ship Today
questionmark.gif This is the part with picture from http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136316. Look in your owners manual because some models cover this part for 2 yrs. Hope this helps.
Nov 18, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Loud whining noise while washing
It may be debris in the food chopper or the motor going bad.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 09, 2008 | KitchenAid 24 in. KUDP02IR Dishwasher
Sep 15, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
