Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
Model HD160U2E5-72 s/n A0575461 is dead
This external harddrive was working fine, but two days ago it was not responding when connected to power outlet.There was no response at all. Any idea what to do?
  • 1 more comment
  • kpr82 Aug 25, 2008
    My acomdata external hard drive was working fine, but in two times it was not responding when connected to power outlet and several days later start to work properly. Two days ago there was no response at all. I remove the actual hard drive from the case and connect it to a usb cable for external drives but nothing happened. ¥esterday when I turn the external drive on again it makes the usual noise and vibration, the indicator of activity pulse with a different color like usual but the computer does not recognize it. Right now there was no response at all. Any idea what to do?
  • vtrockster Sep 21, 2008
    the red and blue lights are alternatively flashing qyuickly. i can hear clicking with each cycle.
  • pcheuk Jan 01, 2009
    How do you open the case and remove the hard drive?
  • 304 Answers
Remove the actual hard drive from the case. Purchase a new external usb case for the drive. You can find them on the web from 7 to 29 dollars. Make sure you buy the right case for the drive 2.5 or 3.5 inch E-IDE or SATA ect. Install the hard drive from the old unit in the new case and you should be back on the road in no time.. Hope this was helpful....
George
Posted on Jul 16, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
No memory compaq presario windows98 need to reboot using just my internet connection i didnt save a backup disk
I understood your problem. Here i providing you perfect solution for this problem.
>Use external USB keyboard
>then if possible also use external DVD Drive
> now boot the Xp or win7 CD/DVD from external drive and format your PC.
thanks for giving such opportunity to solve your problem. have a nice day.
Jan 24, 2013 | Computers & Internet
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
The harddrive was connected with my pc, but it was all turned off. a short circuit must have happened that day, i found the harddrive turned on. probably the arriving electricity turned it on, (it often...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Western Digital My Book Home Edition 500...
It was working fine and then I went to turn it on
If you're connecting a known-good power supply to the MyBook, and it's not turning on... I suspect that the MyBook has died. You should replace it or have it serviced. If the data on it is very important, it might be worth taking the drive apart and removing the hard drive inside and trying to recover data. If the data isn't important, I would say the MyBook is dead. Sorry.
Feb 27, 2010 | Western Digital My Book Essential Edition...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Dead USB external HDD. Disk spins, light is on, but no one is home.
it does sound like the Hard drive enclosures circuit board may be the problem, there are ways to get the data off that will void your warranty, or there are services you can send it to who will get your data back for you and then replace it.
Let me know what your preference is and I can assist you either way.
Chris
May 20, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Power is present, usb is connected, computer is not recognizing the external harddrive
I just had the same problem with my simpletech 500GB. Was working fine and then all of a sudden it wouldn't show up. I was trippin out thinking I might lose everything. After reading up and looking for answers nothing worked no where. So I prayed and asked God to help me figure this out because I had put all of our family pictures in the hard drive and would lose them all if it no longer worked or I would have to re format. Long story short, a few minutes after praying to the Lord Jesus, I got a thought in my head to follow the instructions on the box about installing it. Unplugged everything and then proceeded with the 1,2,3. Plugged in the usb to the hard drive, plugged it to the computer and then I plugged the power box in and low and behold the external hard drive showed up as when I first did it a few days ago. Thank you Jesus for the simple answer on the simpletech. I hope this is helpful to someone out there who is pulling there hair out like I was for a few hours. God Bless all and may the Love of Jesus impact and save your life. HE'S COMING SOON! Be ready
Jan 20, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Acer ASpire laptop
sounds like its trying to load windows but the harddrive is failing to respond, most of the time if it loads everything up to the windows itself its all done before initalizing the harddrive itself.. try putting the harddrive into another computer or usb external to check if its dead.. you might just need a new one =T not 100% sure though but its worth trying.
Jul 28, 2008 | Acer Aspire 5100 Notebook
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
532 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
