Question about HP Office Equipment & Supplies
Printer will not install completely only half way how do I completely install my printer to my computer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If you are trying from the CD, they sometimes are defective and do not install all the way, try going directly to HP site and look for Drivers.
Posted on Jul 15, 2008
Some lines only half printed
Two choices:
(1) Uninstall the printer driver COMPLETELY and then reinstall it.
(2) If that doesn't work go to https://www.Canon.com. Select printers. Select iP2600. Find the driver for that printer - it may have been updated and since Microsoft constantly updates various files your current driver may no longer be compatible with Windows or Mac (whichever you own). If it's a Mac my comment is still valid - lots of updates. I had to do this recently with an HP printer that stopped working. I installed the printer driver update and the printer immediately started working again. This is an ongoing problem for everybody!
Oct 20, 2014 | Canon iP2600 series
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Since conecting my Lexmark P4350 to a different pc it is sometimes only printing half a page and sometimes the print is smudged. can you suggest anything.
Make sure that the printer driver is properly installed. Please visit the Lexmark website to download and install the Lexmark P4350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the install process is complete, try to print again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark P4350 All-In-One InkJet Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
JUST CHANGED BOTH INK CARTRIDGES. NOW ONLY HALF OF THE WORD WILL PRINT. THE TOP HALF WILL PRINT.
Cartridge is bad or there may be a bit of tape over the nozzles that did not come off completly when you installed it.
Nov 20, 2010 | Kodak ESP5250 All-In-One InkJet Printer
After installing maint. kit and new toner cart.still have the left half of pages are blank,right half faded
Hi, try the following. Send a print job of a few pages and when the first page comes out then open the front cover of the printer like if you were going to remove the toner. Remove the toner and look at the Photoconductor. If the image in the photoconductor is complete, no half of the print image and no blurring on the other half then the problem is your Transfer roller. Could be that is not installed properly or needs replacement it could also be that the High Voltage power supply (HVPS) is not sending enough charge to the transfer. If the image of the photoconductor is appearing just like the one printed on paper then the problem could be the charge roller or the HVPS.
Jan 18, 2010 | Lexmark T642 Laser Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
4110 all-in-one
Hi moonwag, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Sep 08, 2008 | HP Officejet 4110 All-In-One InkJet...
15 people viewed this question
Ben Johnson
