Question about Canon PIXMA MP810 All-In-One InkJet Printer
Canon Pixma MP 810
A part of A4-paper was going wrong way in printer - printer blocked - on display came: Errorcode 6A00 . After removing all parts of paper blocking the printer (: controled - realy all parts where removed ! ) , - all should be o.k. again...But not so ! The error code "6A00" stays at the display. How to reset this code system ??
  • 2 more comments
  • Machiel Jul 15, 2008
    My techn. did so, more times - didn't work - machine still blocked with code 0600 at display...Canon advises to send the printer to Canon repairshop - which takes 4 weeks at least...and very high costs ! Only to reset this new ( 13 mnths)
    printer. Hope anyone knows the trick ..
  • Machiel Jul 21, 2008
    Problem solved by Canon Service Centre
    ETB-*** BV - Roosendaal.
    Perfect service - without any costs !
    THANKS CANON , we can use this beautifull machine !
  • natbryan Sep 15, 2008
    I have same error code 6A00 unable to get rid of this error code....Don't know what to do as I really think this is the best copier I have ever had don't want to part with it but they have discontinued this product???? Will have to send it to a canon dealer for repairs....Nat
  • jnhz Jan 16, 2009
    Suddenly the LCD display shows error code 6A00 - we unplugged it from the power source and tried to reset it, but no luck. Is there a solution??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Try moving the cartridge unit back and forth a few times, this usually works.
Posted on Jul 15, 2008
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp 830 all-in-one printer says 6A00,
no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
 Nice
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code 6A00 -
6A00 means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it.
Jun 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Cannon MP830 printer, that is displaying 6A00 error
Yup, the purge thingy needs to be replaced. part number QM2-3032-020. Around $20 bucks for the part, not easy to change.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jun 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
On my MP 830 Canon Error on my computer 5C10 Error on printer screen 6A00 Print head moved top the far right and appears to be jammed Had removed and cleaned printhead, reinstalled printhead and inkwells...
Hi
This happens a lot
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannnon mp-530 shows 6a00
Hi
This is same as the wat full
Solution 1:
Solution 2:
Solution 3:
Dec 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MY Canon Pixma MP 500 Printer won't Print.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
478 people viewed this question
old marine
old marine
