Question about HP LaserJet 2430 Printer
Jet ink on printed invoices
Dear CompuG,
Even though I changed the printer cartridge and it is now printing dark and normal. I am still getting a "run" of ink smudging my invoices.
Can you help?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Clean inside for toner spills
check fuser may be worn
check drum ( green Cylinder of toner cartridge) --Rotate--
Posted on Jul 15, 2008
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Hi, when i try to print from my dell computer, I get half the picture & it comes out in blue. When I run clean cartridge I only get blue lines running across the page. I've checked the ink levels via...
May try new ink jet cartridges, as the nozzles can get plugged up over a period of disuse. Maybe try to wipe the ink jet cartridge nozzles with a cloth soaked with rubbing alcohol to clean.
But, if that doesn't work, then new cartridges are indicated even though they are kind of expensive.
Jan 24, 2011 | Dell 968 All-In-One Printer
All photos, when printed have stripes/bands, especially noticeable on blue sky. Any way to improve, or is that just a problem with the model?
Change the ink jet cartridge for the blue or other colors. Make sure you align the print heads through the printer control panel or 'service' area of the printer on the computer.
If changing the ink jet cartridges and aligning doesn't help, then the printer is at fault. Usually, though, servicing these two things will rectify things.
Good luck with this repair.
Dec 31, 2010 | Dell V313w AllInOne InkJet Printer
Is it possible to print if only one cartridge is full?
In short, No. This is a safety feature built into ink jet printers in most cases. There are some older Lexmark and HP printers that will print the other colors even though 1 Cartridge is empty however these are slowly leaving the market.
May 21, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Even though both the color & b/w cartridge are new my print job is very light
You can try setting that darkness in your menu for set up printing. That will make it darker. If this just happened after changing the ink clean the jets before setting the darkness.
Dec 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer keeps wasting my color ink
The best answer is for you to buy a laser printer rather than inkjet. The laser printer will print at a lesser cost per page than the inkjet, and the color issue will be resolved
Sep 06, 2009 | HP PSC 1510 All-In-One InkJet Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP LaserJet 2430 Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
