Question about EliteGroup C51GM-M Motherboard
Hot power supply possibly damaged motherboard
The fan on my power supply gave out and caused an over-heat shutdown. I allowed the system to cool down for 30 minutes with the cover off. I powered back up and everything worked fine and I worked for about 15 minutes.
I replaced the powersupply with a new one and now at boot up I get regular long beeps from the motherboard buzzer and no movement on the system. I went back in and unplugged all drives except for the boot drive and still nothing changes. I did check to see that all boards, memory and power cable are seated properly.
I reinstalled the original powersupply which is giving me the same error now.
    Sergeant:
    Champion:
  • 327 Answers
Welcome to FIXYA
As what i can tell sounds like the motherboard might of got damaged when you let the power supply over heat
sorry thats what i think
have a good day :)
Posted on Jul 15, 2008
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
I have ( IBM ThinkCentre 80847eg ) after starting power it shutdown automaticly after 30 seconds so i push power button again ,then it takes 3 minutes to get windows logo . so what's the problem
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 29, 2012 | Computers & Internet
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
Power supply has shutdown
It may not be the power supply.
Mar 06, 2012 | Computers & Internet
Automatic shutdown over heating
Turn the computer off.
Remove the side-panel, to expose the motherboard.
Turn the computer on.
When you see PRESS <blah> TO ENTER BIOS SETUP, press the <blah> key.
Use the "arrow" keys to move around the BIOS SETUP menu,
looking for any "system health" menu-entry.
Press the "enter" key to select that menu-entry.
It should report the current motherboard temperature, and the current CPU temperature,
and the temperature-limit, beyond which the motherboard will force a shutdown.
It may also report the speed of the power-supply fan, the case fan (if installed), and the CPU fan.
Also, take a look at the fans, to confirm that they are spinning.
Replace any non-functioning fans.
Jul 13, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
In my desktop every 20 min my desktop shutdown but why. can u give me the solution
Might be problem with Processor cooling fan and heat sink.. check this section properly..
May 31, 2010 | Packard Bell (190169) Power Supply
Fan won't cool enough, causes random shutdown
it could also be your power supply or the presence of viruses/malware
Mar 20, 2009 | Gateway 3250S PC Desktop
Heating of ram
thanks for using fixya.com
heating your ram is only natural specially when you are using your unit.
you can buy a fan for that.
but if he heat is not natural you can go to a computer shop and ask assistance for the technician.
please don't forget to rate..
thanks,
Feb 17, 2009 | Computers & Internet
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Random shutdown
The power supply would have been my 2nd option too. It can build up quite a bit of dust which gets very hot inside and overheats. Good thing power supplies are cheap. I assume since you cleaned the heatsink area that your fan is working and plugged in. A bigger fan might be needed too.
Oct 28, 2007 | Dell Dimension 8400 PC Desktop
EliteGroup C51GM-M Motherboard Logo
50 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
