Xerox XC1045 The toner light came on. I put a new cartridge in and the toner light stayed on after and it won't copy. I tried turning it off and even unplugged it thinking it may need to reset. No luck. Please help! This is the model number.
  • planeapts Jul 15, 2008
    When I clicked on the link- it said "page cannot be display"
To Rest the Drum:
*Turn ON the copier and within 4 seconds press clear, toner select, clear, toner select
*screen will go blank
*enter "24" in the number of copies
*enter "07" in the number of copies
*turn off the copier and then turn it on again.
Posted on Jun 13, 2012
Go to : partsdrop.com
then click on left bottom where it says : Tech Info
click on model # Xerox XC 810 style
click on drum cartridge recon and follow instructions.
Posted on Jul 16, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
  • CheckitRight
    CheckitRight Jul 16, 2008
    Got to : partsdrop.com
    then click on bottom left : tech info
    got to : Xerox XC 810 style
    click on drum recon and follow instructions.
    Good luck
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
I have a Xerox Copier XC1045. Our copies are coming out with dark spot on the paper., I change the drum, but still have same problem, even big area has black spot
You may have a worn out heat roller in the fuser.
It is also likely you have a bad toner cartridge . If the spots are gritty then replace the toner cartridge and vacuum out the machine,
Aug 11, 2010 | Xerox 5665 Copier
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
Aug 12, 2009 | Xerox Phaser 8200 Laser Printer
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Can you help us with a copier problem
That sounds like your toner is empty. Sometimes that cartridge runs out or low on ink and just doesn't display.
What is happening is the density sensor is looking for a nice black patch and the patch it is looking for is gray or almost blank and it stays in a constant cycle of trying to make that ink patch dark enough to produce a copy,
I would try a new toner.
Jun 09, 2008 | Xerox Office Equipment & Supplies
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
460 people viewed this question
k24674
jasbo
jasbo
