Question about HP Compaq nx6310 Notebook
Power-on password I have a problem with my machine. Its about power-on password.
    Genius:
  • 2,028 Answers
If this is a Windows password, then you will need to enter safe mode at start up by pressing F8. Once you're in safe mode, log on as administrator, from here you can clear any user passwords. Now if this is a bios password, then you will need to contact Compaq support.
Posted on Jul 15, 2008
Machine demand password at start
It is asking for Power On Password. Have you added any password on bios and enabled the Power On Password service ?
If yes then you have to remember the password.
Oct 11, 2013 | Computers & Internet
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
Power on password
I am not sure what you mean. Is the unit asking for a password after power up. or is it asking for a password after coming out of sleep. It makes a difference, The first one is a hardware password, the second is a software password. If it is a hardware PW then the make, model and any other machine data you have would be needed. If it is a software PW then the manufacturer and version of the OS would be needed as well as the number of users and if the machine is used commercially or not.
Jul 29, 2012 | HP Compaq nc6220 Notebook
Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Mar 09, 2011 | Xerox 6180MFP/D Printer
Bios password help
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
Feb 17, 2011 | Dell Dimension E521 PC Desktop
How can I reset the h2 bios password on a Toshiba laptop"
Sep 18, 2010 | Computers & Internet
MY DAUGHTER PUT A PASSWORD ON THE COMPUTER SHE DON'T REMEMBER HOW SHE SPELLED THE DOGS NAME i HAVE TRIED EVERYTHING TO UNLOCK WHAT CAN i DO WE DONT HAVE INTERNET WE JUST USE IT FOR GAMES FOR THE GRANDKIDS...
Sep 18, 2010 | E-Machines eMachines Desktop PC
How to reset bios on dell 5400 laptop
Sep 17, 2010 | Computers & Internet
How can I reset password for Bios Phoenix? the problem is that i can't run windows also
Try this, this is called "Backdoor BIOS Passwords" (manufacturers use these passwords for testing and maintenance.)
Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
OR
Try removing your CMOS Battery. (Note that all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.)
Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system.
OR
Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Power on your machine
-jwma
Jan 06, 2010 | Computers & Internet
I have asus mother board support to core 2 duo and quad core recently purchased and inserted quad core processor. Problem is forgot my password. How to avoid that trouble myself
what kind of password? bios or administrator password should be clear!..
if bios password reset it.. else administrator use PROGRAME OR SOFTWARE TO REMOVE IT.. LIKE < password changer which can dowload from the internet... try it..
Sep 12, 2009 | ASUS PC-DL Deluxe Motherboard
HP Compaq nx6310 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
