Question about NetGear Computers & Internet
Setting up wireless network 4 computers with Netgear
I have a Gateway Vista laptop, HP Vista desk top connected to the modem and router, and Gateway Windows XP on two other desk top computers.
How do I set up a wireless network with these four?
  • 2 more comments
  • maruco Jul 15, 2008
    NET GEAR
  • maruco Jul 16, 2008
    My husband set up the router and has forgotten the passphrase. It always asks me for one - how do I find it? What is a DHCP?
  • maui55 Nov 15, 2008
    Similar problem, we have Netgear on two of our laptops. We've purchased a third one and need to set up Netgear for it. But we forgot our passphase. Can we reset with a new passphase? and how?
  • upirons May 11, 2010
    What kind of router do you have?
    Problem Solver:
  • 9 Answers
Assuming they all will work with the version of wireless the netgear works with (802.11a/b/g) then you really just need to enable the wireless network on the netgear and choose how you want to protect it. I recommend using WPA or WPA2 if all your devices will support it - this depends on the wireless cards in all your pc's - just set up a name for the wireless network (not recommended that you use the default because everyone does) set up your WPA/WPA2 passphrase on the netgear and it should be pretty much ready to go. On each pc then, once they are able to see the wireless network with the unique name you gave it, just hit connect in your wireless settings and enter the passphrase. Each pc should be set up.
The only other thing to consider is to make sure they are all using DHCP via the wireless router or, if you prefer setting up their IP addresses manuall, make sure none of them conflict with eachother (each one needs to be unique).
Posted on Jul 15, 2008
Have modem connected to desk top. need instructions or manual to connect belkin router to modem to also receive wireless for laptop.
Connect a LAN cable from Belkin to yourlaptop/computer's LAN port, open a browser on your laptop/computer and enterthe Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 24, 2011 | Belkin F5D7234-4 Router
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
I need help setting up my laptop with my Dsl service. I have a Desk Top computer with DSL and ot one time I had my laptop and my Desk Top pn the same service line. My wireless Gateway 2wire router with...
You can manually go into the network settings and delete the old network configuration, and set up a new one. If all else fails, go to your desktop (which I am assuming connects OK) and check the settings on it, and use those to set up the laptop. Hope this helps
Oct 26, 2009 | Computers & Internet
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
How configuring my netgear wgr614 v6 wireless router?
1. Connect the Netgear wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL ie. http://192.168.0.1
3. Enter the login and password - login = admin PW = password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further secutity measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. remove the LAN cable and the computers should be able to connect to the router.
11. Check the signal strength, if the signal is weak then move the wireless away from concrete walls and locate it higher.
Sep 27, 2009 | NetGear WGR614 Wireless Router
I cant install my wireless router. i moved and
we ll start with the physical connections.
1.take ethernet cable n connect one end of the cable to the modem and the other end to the isolated port on the router(internet port) and then connect the computer and your router with other cable(any lan port).refer the chart on the router to distinguish the internet and lan port.
2.check the light status on the modem and router.
router lite status-power,alphabet i lite,wireless lite(lollipop lite) and the number light lit up(depends on the port eg port no:1 connected number 1 light lit up).
3.check the ip address and default gateway address.
steps:In windows(xp,2000 etc),click on start->click on run->in the search tab type cmd->dos prompt window opens,type ipconfig and u ll get ip address and default gateway address(192.168.1.1 or 192.168.0.1).note it
In vista,start->in the search tab type cmd->dos prompt window type ipconfig->u ll get the address as specified earlier.
4.open the browser,type the default gateway address in the address bar and press enter.The login window ll ask for username and password. username-admin
password-password.
5.You ll enter the netgear smart wizard page.Run the setup wizard at the left side (blue screen).select yes and detect the type of connection.
6.If it is a cable modem-dynamic ip detected and click next.check whether the dns address is given automatically from isp and click apply.Then click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not be 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).
7.If its a dsl modem-the type of connection ll be detected as pppoe.click next.configure your router with the username and password provided by the isp and click on apply.The router ll save the settings and then check the internet port and lan port
address as given in the previous step.
8.Now we have to configure the router for wireless settings(both modems same configuration).
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear2
region:us
channel:11
. mode:g and b
In security options select wep and key1 give your telephone number so that you wont forget the password.CLICK APPLY.we have secured the n/w.
9.scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
10.you ll be able to go online wirelessly if there is any problem delete the preferred networks.
I have given you all the steps with examples to help you configure the router.hope you ll fix the issue and further assisstance im ready to help u but pls give details about your operating system,type of modem and no of computers so that it ll easy for me to troubleshoot.rate me if i have helped you.Thank you. Have a good day
Sep 25, 2009 | NetGear Computers & Internet
Attempting to connect netgear 624 to modem with desk top computer
first call comcast that you'll use a router with the modem.
then connect the cable modem to the router.
then connect the desktop to the router and use the supplied cd.
Dec 12, 2008 | Computers & Internet
Problem with initial install
hello!
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection on both pc
if this still didnot work, upgrade the firmware of your router
May 30, 2008 | NetGear WGR614 Wireless Router
NetGear WG111 802.11g/b Wireless Adapter
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Jan 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Computers & Internet Logo
286 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
