Question about HP Office Equipment & Supplies
Printer. Device door is open. Instruction is: close door to continue. Apart from the main cover on printer, can't locate "a door".
  • sheilapollo1 Jul 17, 2008
    Turned out to be an installation problem which now sorted.  Thanks for your help
  • tamemo Dec 29, 2008
    KEEP GETTING NOTICE TO CLOSE DEVICE DOOR. CAN'T SEE A DEVICE DOOR, EVERYTHING ELSE IS CLOSED
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
The switch for the door may not have good contact,
Open front door locate a small hole and look for a switch insert a small piece of paper and push down, does it turn on? if yes you need to adjust that switch
If no, then try the back door for the same operation.
Posted on Jul 15, 2008
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
Kodak esp 3250 printer error. Remove rear access cover. Clear all paper. Attach cover. I removed the paper, and pressed "ok" to continue, reattached the cover, and it still says this. I tried...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Jan 01, 2011 | Brother DCP-7040 Laser Printer
My Printer is Laser, Cannon LBP3000, while printing paper jammed into the roller, computer gave instruction that "open the top cover of the printer and remove the paper by pulling". But after...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Canon LASER SHOT LBP-3000 Printer
When printer turned on error Dueplex cover
The duplex unit is located on the right side of the copier (facing the copier) The first cover you open (the side door that hinges down) is the duplex unit.
Make sure it is closing properly and fitting tight against the main body.
The open close sensor for the ADU is located at the rear top side of the door. Their is a round hole with a metal plate behind it - this is the actuator for the sensor behind the plate.
To test it, open the door (leave copier on) and press the metal actuator in with your finger - the copier should come to the ready.
When you close the ADU look to see where the actuator/hole meets up with the main body of the copier - there should be a "boss" sticking out from the cover - this is what pushes the actuator to say the door is closed (is it there?)
You could also remove the small plastic cover on the ADU that is cover the side where the sensor/actuator is located. Make sure the sensor is still in place and connected.
You could also try unpluging and repluging the main connector that conects the ADU to the copier (make sure copier is off)
Mar 27, 2009 | Toshiba Office Equipment & Supplies
96 people viewed this question
Ben Johnson
