Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
The green "clean" light just keeps blinking. If I push all the right buttons to start a new cycle, the dishwasher won't start a new cycle. Instead the clean light just keeps blinking? Any ideas? I have a Kenmore Engergy Star Dishwasher model number 665.16023402 that has the clean light blinking continuelly. It mades no differance what I do it will not strat a new cycle.
  • 3 more comments
  • Anonymous Sep 27, 2008
    I HAVE EXACTLY THE SAME ISSUE
  • Anonymous Dec 05, 2008
    same problem
    anyone have a solution?
    Please help.
  • B-52 Jan 09, 2009
    kenmore dishwasher model 665-16029401 "clean light" keeps blinking..prior to this, after a wash cycle, dishes were not clean and not dry.
  • Anonymous Mar 21, 2014
    the dishwasher wont start. the "START AUTO" light blinks steady
  • Anonymous Mar 23, 2014
    complete light keeps blinking and wouldn't start
I had the same problem and was told to unplug the dishwasher, wait, and then plug it back in. That didn't work; but I decided to try again. So I unplugged the dishwasher, wiggled the heating element in the bottom, made sure it was in the right position, and replugged the dishwasher. Eureka! It works. Sure glad I didn't pay $70 plus whatever for a Sears housecall.
Posted on Jan 10, 2009
It says in the manual to check the heating element.
Posted on Sep 10, 2008
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Dishwasher won't start and the green 'clean light' is blinking
your computer has detected a problem , most likely with the water heating. its locked up. Try pushing the high tem wash buton and then the energy saver button , push them back and fourth a few times(some modles its 2 other buttons) This should actavate a service check cycle where all the lights go on. Let it do its thing, and cancle after a few mins. if it locks up again you need service.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
1,180 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
