Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Jul 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Office 2007 Hi, i cant install again my office 2007 it shows " MICROSOFT OFFICE BASIC 2007 ENCOUNTERED A ERROR " i try many times, cleaning registry, deleting office files, cleaning cache, but i can't help please
Arcadian Duran
Level 2:
Sergeant:
  • Expert 284 Answers
  • Posted on Jul 15, 2008
Arcadian Duran
Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
78410
Points
643
Sounds like a HD problem run error correcting utility, and defrag the hard drive, cleaning the registry helps too.
also make sure you have shut off any virus program some dont like it when a program is being installed especially norton ineternet security.
check the disk make sure theres no scratches on the cd.
also bad memory will cause errors. try removing a chip from the computer and installing. ive notice when installing OS's like win xp if you have a bad memory chip it will not install.
Also you can try a different CD rom drive, the one you have could be failing.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
1helpful
5answers
Problem installing office 2007.
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in or Microsoft Save as PDF or XPS installed, this may be the culprit. In both cases, by performing an uninstall on this add-in via the Control Panel, and then installing Expression Web, everything works okay. You can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
Each time I try to install Microsoft offive home and student I get a message saying we have encountered an error during set up please advise me
Type %tmp% in RUN
Delete everything in that folder (if you cannot delete any file, leave it)
Restart computer and start the setup.
If any error, tell me the error number or whatever extra message that it shows.
2answers
Have reinstall 2007 Office. Error Msg and won't install
Once the 3 months expires for one application, it expires for all applications.
3helpful
2answers
MS Office 2007 Enterprise installation setup error
Hi, this may not help you because I do not have the exact error you described. But here is some text from the MS website:The installation of the 2007 Microsoft Office suite Service Pack 1 (SP1) fails with error 1935 or with error 78F. This failure occurs when the Windows Installer encounters a reference either to a drive that no longer exists or to a removable media device that contains no readable media. For example, this failure may occur when the Windows Installer encounters a reference to an empty DVD drive or to an empty CD drive. The issue is not caused by the update design of the 2007 Microsoft Office suite Service Pack 1 (SP1). RESOLUTION loadTOCNode(1, 'resolution'); This issue is resolved by update 946691 for the 2007 Office system. Update 946691 is provided to resolve the problem that you may experience when you install the 2007 Microsoft Office suite Service Pack 1. You must install update 946691 on you computer before you install 2007 Microsoft Office suite SP1.
The following file is available for download from the Microsoft Download Center:
download.gifDownload the Office2007-kb946691-fullfile-x86-glb.exe package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=697BA2AA-0757-42C8-A530-5BD5566A54AD&displaylang=en)
So, here is what they say to do:
Remove the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Exit all programs.
  2. Click Start, and then click Control Panel.
  3. Double-click Add or Remove Programs.
    Note In Windows Vista, click Uninstall a Program or Programs and Features.
  4. In the Programs list, click Microsoft Office Edition 2007, and then click Remove. In this item, Edition is a placeholder for the edition of Office that you installed.
    Note In Windows Vista, click Uninstall.
  5. Click Yes when you receive the following message: Are you sure you want to remove Microsoft Office Edition 2007?
  6. When the removal operation is complete, click Close.
Reinstall the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Insert a 2007 Office installation CD into the drive.
    Note If your version of the 2007 Office suite is a preinstalled version, the installation CD is packaged in the white box that was included with your computer.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for confirmation in the User Account Control dialog box, click OK, or click Continue.
  2. Enter the product key.
    Note If your version of the 2007 Office suite is a preinstalled version, the product key is located on the back of the CD case.
  3. Read the Microsoft Software License Terms, click to select the I accept the terms of this agreement check box, and then click Next.
  4. Select the type of installation that you want, and then start the installation process.
  5. When the installation process is complete, click Finish.
3helpful
4answers
2answers
Office 2007 Install Problems
It can be very aggravating to reinstall Office; you probably need to use the free removal tool that Microsoft provides for situations like yours. It may have nothing to do with Office 2007 and everything to do with whatever else you added via Add/Remove Programs. My best advice is patience; Office12 is huge, and takes a long time to put all its junk in there; Microsoft will walk you through it if you have patience with their tech support folks and time to wait on hold to reach someone. The good news is they get paid to sit with frustrated folks like you. If you can be more sprcific what the error message(s) say(s) that will help whomever could help you get to the root cause of your issue(s).
2answers
i had a friend who had this problem recently.i figured it out though.first go to your add/remove programs and remove office xp completely,then do the same thing with office 2007 .then after they are both removed restart your computer,and then installyour office 2007,the key here is you cant have both on your computer.hope this helped.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
