Question about Apple iPod MA446LL/A MP3 Player
Black apple screen
I recently installed a headphone jack and when i got everything all back together all i get when i power up is a black screen with the grey apple. it also cycles between that screen and the very low battery screen. i have tried downloading the latest itunes, and my computer cannot see the ipod.
    Scholar:
  • 96 Answers
Connect the ipod to your desktop computer Rear USB port and charge it for at least 4 to 8 hrs
Then try to reset the ipod
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Posted on Feb 04, 2009
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
My ipod model a 1285 keeps turning itself off why
iPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Jan 22, 2013 | Apple iPod Audio Players & Recorders
How do I install my sims card into my iphone 3g?
On the top of the phone there is a small hole next to the headphone jack. Find a paper clip and bend it so that the paperclip is straight. Then insert the paperclip into the hold next to the headphone jack and push lightly until the SIM card try slides out. Then insert your SIM cart into the tray and then put the tray back into the phone.
May 21, 2011 | Apple iPhone 3G Black Smartphone
The headphone jack broke. It is kind of pushed into the mixer. Is this repairable?
I repaired mine when that happened.... you have you unscrew all the screws on the top plare there is like 5 or 6 silver ones..Remove faders (2 volume 1 headphone) then remove the top plate. Then unscrew the the black screws on the side and front of the mixer... NOW THIS PART IS IMPORTANT..from the corners of the mixer there will be a little lifts carefully lift the top of the mixer up JUST A LITTLE BIT... have someone hold it or just rest it diagonally so you can unscrew the jack from the back MIC unless you were able to salvage the jack from the headphone if that silver and black piece are gone your going to have to borrow it from the mic... dont worry the mic will still be functional because its better set in that the headphone jack... now use the outside piece and bring the headphone component to the front where its suppose to be so you can screw the 2 back together.. then put every back together in a reverse order and you should be fine.... if you have anymore questions email me at DjAnthem222@yahoo.com
Sep 18, 2010 | Nu Mark Numark Dxm06 DJ Mixer With 12...
Headphone jack is not working
Have you dropped your touch? It sounds like the hardware is physically damaged. If you have Apple Care I'd suggest asking them if they cover physical damage. If they don't cover the damage or if it is out of warranty check out whiteboxservice.com they'll either send you a box or your can ship to them to diagnose the issue. This is the pricing chart.
Jun 18, 2010 | Apple iPod touch
My iphone won't turn on
You have to hold the power and home button at the same time until you see the Apple logo on your screen.
Hope it helps.
Dec 20, 2009 | Apple iPhone Smartphone
Need to know how to use Apple Pro Speakers with Apple iMac Comp.
Does your iMac have a headphone jack, this is an output source that can be used to input to other amplified sources. I'm not sure what type of connector that is on your Pro speakers but if it has a universal jack then plug this in the headphone jack on your computer.
Oct 03, 2009 | Apple Audio Players & Recorders
Toshiba A75 Wont Boot up
It sounds like you may not have made a good connection to the motherboard from the screen when you put everything back together.
When you press the power button does the screen come on and then go off or does it not come on at all ?
If it comes on then turns off try to eject the CD-Rom that will be a definitive test of whether your power is still on, assuming your cd-rom is not totally mechanical.
Jan 29, 2009 | Toshiba Satellite A75-S226 Notebook
Can bose wires be splice?
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Nov 09, 2008 | Bose in-ear headphones - Black with...
Apple iPod MA446LL/A MP3 Player Logo
51 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
