Back to:
Tags:
RCA WSP150 Main / Stereo Speaker
RCA wsp150 wirelss speakers
posted by jimwide on Jul 15, 2008
I need a power supply. How do I find one that is compatible?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 16, 2008
Thanks for Trying (70)
imajoebob
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
Jim, just about any generic power supply will work, so long as you match the output and polarity.  There should be a label on the old supply with the voltage and Amps (milliamps, actually), and a circle-in-a-circle with a + or - that tells you the polarity.
If you're not sure enough to just buy one from Target, spend an extra buck or two at Radio Shack.  Bring in the old one and ask for a replacement.  You may end up with an adjustable adapter with interchangeable tips, but it will work just fine.  Sometimes the mA are a little different, but that should be okay, so long as it meets the minimum requirement on the label.
I have a pair of these running my WSP 250's.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on RCA wsp150 wirelss speakers:
I don't want to Accept this solution
Can you Help with these Home Theater Speakers and Subwoofers problems?
I ordered the caps that you specified in your fix. Do you...
hi i have a telefunken surround sound that i cannot get to...
I can't play mp3 and dvds that i copied from my pc. Seems...
Hello, Problem with Panasonic home theatre model SA-HT540...
One of the output transistors shorted, a 2SC3281. There...
Loading problems.
Repair Service
Find Home Theater Spe. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
