Question about Bunn A10 Coffee Maker
Bunn 10A My coffee Maker is so slow...I fill the water & put it in & it takes 20min to filter through...the machine is not even2 mo old...It has acted this way since we got it, but some days it works fine... I have cleaned it & ran the wire up in it but still slow...??? any ideas? Kathy
  • Kelley Hopper May 11, 2010
    Is it slow if you only brew with water - no coffee filter and no coffee?
  • 3 Answers
Run a mix of 1 part lemon juice or white vinegar to 15 parts water through the machine and re-pour the same mix in the machine twice more.  then run fresh water through until it comes out clear in the pot.  Your machine needs to be de calcified you can also remove the top plastic cover that has the grate built in to it and in the back on top you will see a nut with a hole in it that the water runs through when you pour it in.  Take the bulb off of a turkey baster and put it over the nut after you have put water in the machine and use like a plunger.  squeeze the bulb several times to push through any loose calcium that might have been building up.  make sure that the bulb is under water put in the machine when you do this.
Posted on Jan 02, 2009
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
I have a bunn coffee maker i do not know hot to make the coffee. i have all the things i need to make it thow
Put the filter in, put the coffee grounds into the filter, put water into the machine, put the coffee basket into the machine, put the pot under the spout, press start.
Nov 13, 2009 | Bunn NHB Coffee Maker
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
Oct 05, 2009 | Bunn VPR Coffee Maker
Just bought a Bunn coffee maker at a garage sale great condition how do you make the coffee I have poured water in turned the side switch on and the warmer switch yet nothing?????
The machine requires an initial set up to be completed before using it. Fill the decanter with cold water and close the lid. It will take 3 minutes to partially fill the water tank in the back. Then fill the decanter again with cold water and pour in and close the lid. Then plug in the machine and turn the vacation switch on the side of the machine on. After 15 minutes, you will be ready to brew coffee. Then you will get your filter basket ready with the filter and grounds. Pour in from 4-10 cups of water and place the decanter on the base. Close the lid and the coffee will begin to brew. If you will call customer service with the model and date code, a use and care manual can be sent out to you at no cost.
Sep 06, 2009 | Bunn NHB Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Bunn A10 Coffee Maker Logo
206 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
