Does not do anything other than fill up and empty
  • phendrick Jul 15, 2008
    no its the buttons not responding for some reason but thanks for reply
  • 254 Answers
You might have the drain hose too far down in the stand pipe, try pulling drain hose up a little.
Posted on Jul 15, 2008
I have a canon mg5320 printer. I just filled 4 of yhe 5 cartridges but it still shows them almost empty, what can I do?
This is perfectly normal. Your printer has no idea you filled the cartridges. Keep using the printer - until it stops with 'ink out' error, then press the 'OK' button (on printer) momentarily. If that clears the error, you can resume printing.
If pressing OK doesn't do anything, press and HOLD the 'STOP' button for about 6 seconds - or until the error clears. This will disable the ink monitor - for the 'empty' cartridge.
You will have to repeat same process for each cartridge that turns 'empty'. Once all cartridges are disabled, you don't have to do anything - except keep refilling the ink.
You can find more info on this here: http://inkbank.com.au/webcontent20.htm
Canon ink level monitor ink tanks how to disable
Feb 27, 2015 | Canon PIXMA MG5320 All-in-One Printer
Hi michael is there anything else i can try bud thanks
the module is only there to control the motor you say it does not fill up or do anything but empty and you have changed the timer or just the selector
Nov 30, 2011 | Washing Machines
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Washing Machines Logo
Top Washing Machines Experts
