NO COLOUR FOR DVD DISKS
No colour while playing DVD but ok with vcd
    Champion:
  • 220 Answers
Your DVD must be NTSC and you must be watching on Only PAL TV.If your DVD has a setting for Output Video system set to PAL.This may help
Samir
Posted on Jul 16, 2008
Cd and vcr to tv
did you mean how to connect the vcd and vcr player to the tv? if so then its simple. just get the provided rca cables and jack in in the appropriate places as the tv and the vcd/vcr are colour coded to make it easy for anybody to be able to connect.
Sep 29, 2011 | Philips Magnavox DVD/VCR Dual Player
Cannot play VCD from India
Your player can't play vcd or divx disks - it doesn't have their codecs in the firmware, at least at this moment.
It's strictly only for BR and DVD.
Sep 18, 2010 | Sony BDPS470 Bluray Disc Player
I have philipd\s dvd player model no. DVP3126K/56.
Check with other DVD disks, see if it play,might have bad disk in that one,like scratches,cracks,or smushes.The disk u playing is a chamerical DVD Disk right?Not burn disk?Might just go in Ur DVD player just reset every setting back to the factory setting.
Oct 31, 2009 | Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
No Colour when playing DVD
  1. Was the DVD player hooked up correctly?
  2. If only black and white then check the video output in back
  3. It maybe on the Y. Pb. Pr check to see.
Nov 25, 2007 | RCA F19430 19" TV
When playing DVD no sound but VCD sound OK.
dvd are up to 6 times the density of a cd there making the laser eye read much closer rings on the disks. so in other words its having a hard time reading dvd. the only thing you can do is take a cotton swap dipped in alcohol and open the tray look with a flashlight for a small optical eye in exact center of dvd player and rub lightly on it to remove dust build up or spray some canned air into the dvd youll hit it. try it again and if no sound again the computer cant keep up with the dvd or vise versa.
Aug 21, 2007 | Sony DAV-X1 System
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
