Question about Canon CanoScan 4400f MultiFunction Color Printer
Scanned 35mm slides show as negative colour - Canon CanoScan 4400f MultiFunction Color Printer
  • ernest2 Jul 16, 2008
    Thanks Andre
Reread instuctions. What else? Andre confirmed it.
Thanks
Posted on Jul 16, 2008
Bought mine this morning! Same problem, but when following steps as per p4 "Try Scanning" it worked very well.
Andre South Africa
Why do my slides only show as negatives
There may be a setting in the software to enable you to correct this - if not, then you'll have to deal with it in post-processing.
Jul 23, 2016 | ION Audio ION FILM 2 SD 35mm Film and...
My scans look like a negative and not a photo
When you go to scan your slides, the software should have a setting for "slides", or "negatives". Make sure you select the correct one for what you've put in.
Dec 31, 2014 | ION Audio ION FILM 2 SD 35mm Film and...
How to scan negatives?
You will need to check your Canon software that came with your Pixma MX310. I have a stand alone Canon Canoscan 8800F scanner that have the capability to scan 35mm film strip and 35mm mounted slide, the software included the feature for it.
Nov 07, 2013 | Canon PIXMA MX310 All-In-One Printer
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
I am having problems scanning 35mm slides, I seem
you have chosen normal preview
1. change it to thumbnail preview
2. or click on "All" button in normal preview
so you would scan multiple negatives.
increase your dpi setting or your target area or both
I am also scanning color negatives at 3600dpi and 48bit. file is large but quality is very very good...
Mehboob Riaz, SIPA, Lahore-Pakistan
Jul 08, 2010 | Epson Perfection V700 PHOTO Flatbed...
Scanning 35mm slides
No you need a slide scanner inkypete
Apr 22, 2009 | HP PSC 950 All-In-One InkJet Printer
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan 4400f MultiFunction Color Printer Logo
351 people viewed this question
old marine
old marine
