Question about Toshiba Computers & Internet
1800 that will not reg. disc. light on side just blinks, go to start tab and thru windows my computer, show a drive and c drive no d drive running 98
  • 177 Answers
Try refreshing your settings under Device Manager,make sure drive is enabled.
Posted on Jul 15, 2008
Cannot boot computer -acer aspire T180 097Z . At first a blue screen saying "error fatale" came; computer rebooted normally; next day on booting first says pressF12 as normal then blue screen...
First you will need a Windows Operating System Disc or Linux. I suggest Ubuntu witch you can get for free here at http://www.ubuntu.com/download.
Next insert the disc and reboot the computer.
The computer should boot from the Windows or Linux Disc
If it does not you may need to go into the BIOS by pressing your BIOS access key as soon as you turn the computer on. These are commonly the F12, F2 and F11 Keys.
If using windows wait for setup to load and the screen should look like this.
Press the enter key.
Accept the windows XP licensing agreement by pressing F8
Choose what Hard Drive to install Windows XP on
After this choose to format the Drive Using the NTFS (Quick) method.
Windows will now automatically install itself.
Follow the Prompts until you get to the Windows XP CD Key window.
Insert your windows XP product key located on the CD box or case it came in.
Follow the rest of the prompts and Finish the Installation and you are ready to go.
There may be other drivers needed to complete installation of all of the hardware.
Here is the Driver page http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=386
To install Ubuntu download and burn to a disc the 32 bit version.
Insert the disc and follow the onscreen prompts
Ubuntu will guide you through the setup. Ubuntu should work without any extra drivers.
Also Ubuntu does not need antivirus.
If you choose Ubuntu i suggest signing up at the forums for community support.
The forums are here http://ubuntuforums.org/
I hope my guide here is helpful.
Please Remember Windows XP is no longer sold in the store and be wary of online sellers as they may try to scam you.
Jul 01, 2011 | Acer Aspire T180 PC Desktop
Problem installing USB to serial port connector/brifge
When an USB drive makes problem on one computer only then an updated mainboard/chipset driver may help.
If it doesn't help then it may be just incompatible with the computer's USB ports - that's not unusual. Therefore it's helpful to have an additional USB PCI card as alternative in the computer, best with NEC chip.
Cheap USB extension cables may cause problems too. The thinner and longer the higher the risk for problems. The plugs wear out in time.
USB ports on front of the computer are more problematic because the USB is leaded by a cable thru the computer case which is full of interferences. Furthermore the port a mechanically stressed, so the usually fail sooner or later.
Other attached USB devices may interfere, usually such ones that don't use a default Windows driver and which permanently transfer data, such as web cams.
Cheap USB hubs die slowly. First symptoms are disappearing devices and communication freezes.
If an USB device has been detected as 'unknown device' once it might be necessary to delete it in the device manager and replug it then.
Another try is a complete USB device clearing by Microsoft DEVCON and the RenewUSB.bat from http://www.robvanderwoude.com/devcon.html
A cleanup can be done manually too. Put the following two lines into Notepad and save them as DevManager.CMD:
set DEVMGR_SHOW_NONPRESENT_DEVICES=1
devmgmt.msc
Started thru this DevManager.CMD the Windows device manager shows non present devices too if you check "View" -> "Show hidden devices". Under "Disk drives", devices shown with a light gray icon are non present. Just delete them. Same procedure under "Storage volumes". There may be a lot of them...
My commandline tool DriveCleanup does it for all currently non present storage volumes and USB drives.
Microsoft has set up a page for General USB troubleshooting in Windows XP
To have DEVMGR_SHOW_NONPRESENT_DEVICES=1 set permanently, download and doubleclick this file: DevMgr_Show_1.reg. After next logon it takes effect.
It also sets DEVMGR_SHOW_DETAILS=1 to get the "Details" tab in the device's properies dialog under XP.
Thanks For Using Fixya
Sep 10, 2009 | Computers & Internet
Problems connecting to the internet
unplug from power all things then plug back in,in this orderthe modem,then in 2 minutes,the computer,it should reset
Apr 20, 2017 | Dell PowerEdge 1800 Server
Playstation3 startup problems
contact sony at 1800-345-7669 then can repair it for you your memory chip could be fried and that is where menu screen data is located
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My dvd drive is not being seen, computer states software problem code 19. HELP
Hi Samholden,
If I understand correctly you are not able to find your DVD/CD drive listed under the "My computer"(computer in Vista)
When You try to use the Disc on the Drive,the Error"code 19" Pop's up.
Is the Light indicatng the Power to the Drive showing On.
If Yes Please Follow this solution For XP (operating system)
Click Start,
Right Click My Computer.
Click Properties.
(you should have got the system properties window Open)
Click Hardware TAB
Click Device manager Button
Look through the list to find the DVD drive (icon)
if you Find it and see a "+" sign Click it to make it "-"
then Observe the sub menu that appearce, (Reply to us if there were any of the alert Icons along with the ICON)
Right Click the sub-menu and Click uninstall.
then Restart the computer again.
please ask if you find ay Difficulties.
Thank you
Jul 17, 2008 | Computers & Internet
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
I HAD A POBLEM WITH WINDOWS WHEN I BOOT UP ALL I GET IS MY DESKTOP BACKGROUND NO FILES NO START BAR NO PROGRAMS. I PURCHASED THE MX1 THINKING I COULD PLACE MY HARD DRIVE INSIDE AND ON MY NEW DESKTOP COULD...
Windows includes a feature called Active Desktop. One of the symptoms of Active Desktop is that it can hide all your desktop icons. To disable active desktop, right-click on the desktop, choose Properties, go to the Web tab, and uncheck "Show Web Content on My Active Desktop".
If that does not work right away, try rebooting the PC after making the above changes..
May 29, 2008 | Computers & Internet
C:/,d:/ problem
hi there,
firstly u had a virus on your system... but u know this aleady... so lets deal with what the virus left behind...
try this out:-
Open the Windows "Start" menu and select "Run...". In the Run box type
C:\autorun.inf -r -h -s and click OK
then
E:\autorun.inf -r -h -s
OK and so on for all affected drives.
Finally check the volume root of each drive for autorun.inf file.
Is that file present in any drive? If so, manually delete it.
then do this:-
1. You have to tell Windows to show hidden and protected system files first.
2. Then you should search your computer for all instances of files with the name autorun (ANY extension) and delete them. DO NOT DOUBLE-CLICK on discs that have any such files because you will again be infected!
3. Launch regedit - but make sure u backup your reg. first...
a ) Find the key:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows NT/Current Version/Winlogon
and check the value of the parameter Userinit. This should read C:\WINDOWS\system32\userinit.exe, nothing more.
If Windows is installed on another disc, then, of course the disc will be indicated.
b ) Completely delete the following key:
HKEY_CURRENT_USER/Software/Microsoft/Windows/Current Version/Explorer/MountPoints2.
This last step should be repeated for all user accounts on your computer. You should then restart your computer and that's it.
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
