Question about Sony SLV-679HF VHS VCR
Error Codes Hello, I have two Sony SLV-679HF VCR's . . . both with what appears to be the same problems. The cassette won't eject . . . it sounds like it's trying . . . and they are showing what I believe are two error codes: 11200 and 71501. Does anyone know what these mean and can they be fixed? Thanks!
  • cr1761 May 11, 2010
    In reply to your Email, no I have not received any replies. Still need to find a fix to the problems. Thanks!
4 Suggested Answers
  • 4234 Answers
SOURCE: Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Posted on Aug 31, 2009
  • 579 Answers
SOURCE: sony slv 700 hf
The VCR is detecting something it doesn't like. Could be a foreign object inside, or the gearing out of time or ... Take the cover off and watch it as it loads and you'll probably figure out why.
Posted on Dec 31, 2007
SOURCE: sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Posted on Jun 25, 2009
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
I need the video head for a sony slv 815
The parts you are looking won't be easy to find, go online to sony, contact customer support, and the technical department to see if they can help, if not! try and find a repairman that still repairs vcr's, because he would have access to part suppliers that may still carry what you need.
Apr 21, 2012 | Sony SLV-N81 SLV-N81 Video Cassette...
Where can i buy new belts for this model SLV679HV
Now days it's all about trial and error w/ vcr belts. Your best bet is to find a tech that has several of the old belts in stock. It doesn't have to be exact, but needs to be very close in size to the original.
Nov 02, 2010 | Sony SLV-679HF VHS VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Unit was dropped but works ok except for rewind function
Not worth repair,VCR very cheap these day.Gear under parts,probably can't put it back,must take alot of parts aparts.
Nov 22, 2009 | Sony SLV-679HF VHS VCR
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
Sony slv-960 VCR cassette stuck inside
Jun 25, 2009 | Sony SLV-675HF VCR
Sony SLV-679HF VHS VCR Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
