Question about FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard
How can i solve this problem??
The computer keeps freezing during a windows installation, and if i use the reset button it will just freeze at start up and i will not any vedio output.
I need to know were the power sw and the p led +, and the p led -, and the hdd led , and the reset sw go on the mother board go
Posted on Mar 23, 2009
    Scholar:
  • 101 Answers
This sounds like classic bad memory. If you have more than 1 stick of memory, try swapping them 1 by 1 until it doesn't crash anymore, and you will find the culprit.
Posted on Jul 16, 2008
It keeps freezing and i have reset it several times and it just freezes
Your computer may be freezing because it probably doesn't have enough RAM, since it is a netbook. Try not to open too many programs at once, because that will make a computer with a low amount of RAM freeze. Hope that helps.
Mar 06, 2011 | Sylvania G-Netbook
My computer, Windows XP, freezes when I use Firefox
Your system loaded with Windows Xp Operating System might get affected by various viruses and malware. The antivirus softwares installed in your system for the removal and prevention of viruses from your system cause the freezing issue. This antivirus softwares might take too many time to load and it also make the entire system slow to boot. The antivirus programs result in the freezing of the Windows Xp during start up. Thus you need to temporary uninstall the antivirus software during the start up of your system.
Jan 05, 2011 | Computers & Internet
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
Games, video keep freezing
your vc might be heating up, try to remove it agai. take the heatsink out and then put a thermal paste on it before returning it on the vc, then install it again and see if that will works.
Apr 07, 2009 | Computers & Internet
Freezing of Power producer 2 during last phase of DVD file making
IF THE PROGRAM FREEZES AT THE SAME POINT EVERYTIME, YOU CAN ASSUME THAT YOUR PROGRAM OR SOFTWARE INSTALLATION IS CORRUPT. TRY TO DELETE AND RE-INSTALL THE PROGRAM AND SEE IT YOU CAN GET A CLEAN INSTALL. REPLY TO ARCLIGHT1217 WITH WHAT YOU FIND OUT!
Nov 14, 2008 | CyberLink PowerProducer 2 for PC
Start up problems
I had the same problem few years ago with my 3950
I kept it on the charger and it just kept doing that, and finaly died totaly.
I send it to repairs and found out it was a motherboard / chipset problem and the motherboard would need to be replaced.
Mar 01, 2008 | HP iPAQ hx2410 Pocket PC
Garmin c330 freezing
I am happy to say my problem seems to have been solved. I found 3 possible solutions during my search - may need to try all of them to see if it works. 1) Reset by pressing the button under the faceplate. (Did not work for me). 2) Master reset - switch off the unit and press on the right bottom corner of the LCD and switch it on. Release the power button when it powers on, while pressing on the R lower corner. This is supposed to erase all prior data. I could not master reset my unit, for whatever reason. 3) Software update: http://www8.garmin.com/support/collectio... If you are a windows user you will want software version 2.4.1 as of April 3 2007. This worked for me. Thanks.
Sep 22, 2007 | Garmin Nuvi 660 GPS Receiver
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Computers & Internet Logo
110 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
