Question about Cuisinart DLC-5 Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
  • 2 more comments
  • Anonymous Dec 11, 2008
    I am looking for a manual for a food processor DLC - 7P
  • Anonymous Dec 23, 2008
    I have a DLC-7P Cuisinart. The plastic bowl is breaking. Now we have to hold it in place to make it work. We love our Cuisinart, but we need a bowl that works. Does anyone have anything that can help us?
    wnf
  • muskokawrite Feb 22, 2009
    We have a similar problem. The plastic on the bowl secion is cracking, and pieces are now breaking off. At the same time, we can't get it to chop anymore, probably because the plastic parts aren't pressing down on the switch in the right way. I have tried all sorts of wiggling, pressing with my fingers, etc., but no dice (!)
  • Cynthia Kosman Oct 04, 2012
    did you find a manual for food processor DLC-7P for Cuisinart? Looking for one as well.
    Guru:
  • 174 Answers
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Posted on Oct 13, 2012
  • 8,596 Answers
I would buy the replacement DLC-7 amber bowl parts from an eBay buyer - to buy replacement bowl parts from Cuisinart directly for that model will cost somewhere near $120 - nearly as much as a new food processor.
Posted on Jun 04, 2009
My cuisinart DLC-1ss will not start once plugged in.
The bowl must be locked in the correct position for the unit to turn on.
Remove the bowl, place on unit and rotate into place.
Oct 04, 2010 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
I have a cuisinart pro classic food processor, and even though bowl and top are locked in place, it will not start.
On the processor look at the bowl and lid and see where they are supposed to engage the motor. If this is broken then that is the problem, find something to push on where the part of the the bowl and lid assembly would push, if it comes on then you have figured out the problem.
Apr 17, 2010 | Cuisinart DLC-10S Pro Classic Food...
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
It will not start no matter how well everything is in place and locked.
I had the same problem until I called Cuisinart. The handle of the bowl needs to face you. Have you tried that as well?
Jul 25, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC- 8M
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-5 Food Processor Logo
1,039 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
