Question about Frigidaire Refrigerators
Need to replace thermostat in a frigidaire fridge model number frt18p5a need location of thermostat and reference pictures
Just bought new refrigerator
Posted on Jul 16, 2008
How do I get parts for a frigidaire refridgerator
Good Afternoon jgl1222 - Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor).
May 11, 2013 | Frigidaire FRT18P5A Top Freezer...
The refrigerator temperature stays at 60 degrees regardles of seting
just check whether your thermostat is working properly .....
Aug 03, 2008 | Frigidaire Refrigerators
Tip
My Frigidaire Dryer is not heating anymore. Repair and testing for model...
Hi.
The example is referring to Frigidaire electric dryer model FEX831CSO. If you have a different model see here how to locate parts and diagrams: Where do I find parts and diagrams?
First part to test is the thermal fuse located at the back of the appliance. This is tested reading Ohms on fuse contacts. follow procedure explained further below to test the fuse.
If the fuse is not the culprit, it will be neccessary to access heater assembly and thermostats.
You access the heater parts by opening the top panel, part 3 on diagram below.
The heater assembly is part of the housing, and it is part 15 on diagram.
Replacing the heater requires further disassembly, first ensure that the problem is not a defective thermostat or thermal limiter. The thermostats fails far more commonly than the heater.
To test heater and thermostat use a multimeter set at Rx1. disconnect the thermostat contacts and read impedance at room temperature.
If the thermostat is good it will read zero or very low impedance.
An alternative way to test a thermostat is by jumping its contacts.
The element is also tested reading impedance. If the element has no continuity (infinite Ohms), then it must be replaced, otherwise it is good.
Test both the thermostat and the Thermal limiter, they are tested in the same way. Both this parts are accessible after removing the top panel, and can be replaced without further disassembling.
Here the parts:
Thermostat:PS446428 part 33 in diag.
Thermal limiter:PS419402 , part 36 in diag.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Apr 09, 2010 | Frigidaire FEX831CS Top Load Stacked...
Frigh won't get cold enough
check the slot between the freezer and fridge with this model the freezer cools the fridge there a door in the slot make sure it is opening properly
May 26, 2012 | Frigidaire FRT18P5A Top Freezer...
Replaced the defrost thermostat 2 weeks ago now it's freezing up on me again. Not cooling the fridge side. Any suggestions
Pretty common problem and likely to be caused by the failure of a fan which distributes the cooled air between the two cabinets.
When the compressor is running, open the fridge, locate some obvious vents, normally in the inside rear near the top . Hold your fingers close to these and if there is little or no air movement, the fan has stopped.
Go to the link below and enter your model model number to see if Sears has your unit in their library, thousands are, and if found, you will have a line drawing of your fridge which will help you locate the fan and decide if you want to DIY or have a pro replace it:
Sears PartsDirect
Feb 02, 2011 | Frigidaire Refrigerators
FRIDGE NOT COLD, FREEZER COLD
there may be a large amount of ice build up on the evaporator coils.you alos need to check and make sure that the evap fan is running in the freezer compartment.if you do not here the fan running when the ridge is in a cooling mode replace it. if there is alot of ice you may need to replace the defrost timer
Jun 02, 2010 | Frigidaire FRT18P5A Top Freezer...
Ice In Freezer Vents
thick frost on the back wall indicates a defrost problem, either with the defrost control, the heater, or the bimetal thermostat. Without personal inspection, i cant tell you which one it is, but i can narrow it down to those three
Mar 01, 2010 | Frigidaire FRT21H7AS Top Freezer...
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
Flashes e f code
This is a combination of problems. I have a Kenmore Elite labeled Frigidaire model 253.44513601. If you are reading this you are aware that Kemore/Frigidaire refer's are JUNK.
I have went through TWO Kenomre Elites since 2001. My lateset Fridge (bought January 2007) suffered the "E F" code.
At first I replaced the Evaporator Fan (behind freezer compartment.) This did NOT solve the problem. I then bought a new control board located under the freezer. (take off toe plate, and removes screw, the board slides out and is connected by 3 wire harnesses.)
My fridge is now running, but it has yet to get "cool." This maybe because the User Interface needs to match the control board. Not sure yet, but I will keep posted.
Jun 06, 2009 | Frigidaire Model: PHSC39EHSS
Refrigerators Logo
222 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
