Question about Philips FR965DHT Receiver
No sound output
Unit has been in storage for about one year. I set it up for audio for TV and DVD player- cannot get any output - not even in test mode for speakers. What am I doing wrong?
  • 2,071 Answers
No sound problem is power amplifier trouble maybe the IC there is defected or cold solder of joint of the parts.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 15, 2008
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
Hello. I have my HK connected to a new Sony TV. I see the video pic but hear no sound. I've made sure the TV speakers are on. Not sure what the problem is. Thanks
hi,
Check the connections you have made between the tv and dvd player, whether you have connected the audio output of the dvd player to your tv.
if its ok the go the system setup of you dvd player and then go to the Audio setup.
In the audio setup select digital output and make it to PCM.
exit menu and test
ok
Apr 11, 2011 | Harman Kardon DVD-22 DVD Player
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
No output from DVD/CD player to TV
Best bet/least effort is to get a newer, slightly more robust DVD player. This unit sells for less than $30. It costs more to ship it over from China than it does to manufacture the player. No kidding! For an ultra-cheap DVD player I'd go with a ~$35 player from wally world. Best of luck.
Feb 27, 2009 | GPX D1816 DVD Player
Dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
Apr 11, 2008 | Philips DVP5960
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
Philips FR965DHT Receiver Logo
376 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
