Question about Brother HL 5250DN Laser Printer
Slow to print, very slow
Printer takes about 1/2 hour to print a document. I've reinstalled the software, drivers, etc to start over cause it worked fine for about a year but now this.
  • wnjgr Sep 02, 2008
    Printer stops 3-5 seconds between a second copy of same print job. Just switched this printer out from the same model, and didn't have that problem.
  • Anonymous Dec 18, 2008
    Same problem, send a document from any one of 4 PCs & Macs networked to it and the document takes 20 minutes before it starts to print.
cropp
  • 377 Answers
SOURCE: Printer won't print word perfect doucments
hi dear
try to save your document with save as
change to another name
and try to print again
oke
Posted on Mar 27, 2008
  • 12 Answers
SOURCE: Brother HL 5240 won't print
Right Click on My Computer, and select Manage. Look at Device Manager and look for any yellow exclamation marks. It may not be installed.
Posted on Apr 25, 2008
  • 13 Answers
SOURCE: wont print or only few pages
sounds like a Mpcb malfunction.(expensive now its out of warrenty) you can replace the printer with what the repair
would cost you.
Posted on Jul 03, 2008
  • 3 Answers
SOURCE: Very slow PDF and large files printing
It has nothing to do with your files but with a setting on the copier. Press*utility*user management*number 5 or 6 and make sure to select priority device to printer.
Posted on Jul 10, 2008
  • 79 Answers
SOURCE: Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Posted on Sep 02, 2008
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Why slow startup (10 min) and slow printing (+ 1 hour)?
www8.hp.com/us/en/support.html
Sounds like you may have a mechanical problem with the printer itself.
Aug 18, 2014 | HP PhotoSmart C4180 All-in-One Color...
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
Printer takes forever to print
How is the printer connected to your computer(s)?
If it is USB or network. Try a different cables.
Does your computer run slow also? Low disk space can cause print jobs to print slowly.
Network issues can cause slow printing as well. If your printer is on network and there is a mismatch of 10/100 Mbps speed or Half/Full duplex, the printing can be slow.
If your OS is Windows, remove the printer from Printers and Faxes. Uninstall the driver package if installed separately. Download the latest drivers and install them and reinstall the printer.
Apr 15, 2013 | Lexmark MS310dn Monochrome Laser Printer...
My primter - hp psc 1400 all in one has been
Check the print options and make sure that you have set the printer to start printing while the document is being spooled to the printer.
Most of these printers put the intelligence into the print driver which then spools raw raster data to the printer.
Are you trying to print a very complex page, i.e. pictures and boxes as well as graphics?
Don
Oct 22, 2009 | HP PSC 1410 All-In-One InkJet Printer
Network copier printing very slow when printing bulky document
turn collate off the printer will treat each page as a separate job slowing the machine down.
Apr 25, 2009 | Ricoh Office Equipment & Supplies
Slow Printing
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Apr 24, 2009 | HP LaserJet P3005n Printer
Slow speed of prining
try doing upgrades on the printer
Nov 11, 2008 | HP LaserJet P3005n Printer
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
try a different pint driver such as a pcl4or5e.
Apr 15, 2017 | Office Equipment & Supplies
Brother HL 5250DN Laser Printer Logo
181 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
