Question about Frigidaire FRS26R4A Side by Side Refrigerator
Fridgidaire side by side Ice cube jam
Every since it was new ( 2 1/2 years old) this problem is recurring. Ice cubes pop out and get jammed between the rake that pushes them out of the tray and the top of the freezer tray. Once jammed it stops making ice. I can remove the jammed cube and it works fine for a day , a week,or a month but always seems to be at the wrong time ( people over for drinks,parties,etc.) This has to be a problem for many people owning them.
  • 725 Answers
You can adjust the size of the ice cubes . if the cudes are too small or to big . they can get jammed... the timing screw is under the head cover clockwise is smaller . turn it one turn at a time... hope it helps
Posted on Jul 25, 2008
We have a U-Line mini fridge with ice maker. 1 month old and 1 week ago it started making "working too hard" noises. 1 week ago we had paused the ice making function. Related ?
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
Jul 20, 2017 | U-Line Refrigerators
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
I have no manual and I want to make ice cubes and be able to drink filtered water. I do not get any ice cubes when I switch the button on in the left rear. I am not getting water. I have removed, to...
1. Keep freezer temp setting @ 5 degree.2. Check water supply with full pressure (Back of regrigerator) 3. Confirm shut off arm is not struck due to huge cubes stored in bucket. If so, please remove ice cubes.4. Check solenoid valve which allows water flow whenever required to ice maker is working.
Please follow the steps also given hereunder.
Close the freezer door completely. The dispenser will not work while thedoor is open. Place the ice bin in the proper position. Avoid placing ice inthe bin that was not made by the ice maker. The cubes may jam in the deliverychute. If ice is jammed in the delivery chute, remove it with a plastic utensil.Discard the ice in the bin and wash it if ice has melted around the auger. Drythoroughly before replacing it. Wait three minutes if the dispenser stopsdispensing ice after the arm has been held in for a long time. The dispensermotor will reset and will begin to dispense ice again.
Thanks
Jan 29, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
ZIS480DRISS NO MAKING ICE CUBES
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Jan 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
115 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
