Network access to windows 2003 folder
IT in a workgroup
  • 19,396 Answers
Not Sharing pc for win 7
It may be because of the workgroup setting. WINXP uses a default workgroup value of MSHOME. WIN7 uses a default of WORKGROUP. What happens then is that all computers can connect to the network and access the internet, but shared files and folders will not be seen due to the two different workgroups,
To change the workgroup in WIN 7:
Click START.
Right click on COMPUTER, choose PROPERTIES.
In the SYSTEM window, choose ADVANCED SYSTEM SETTINGS
in the SYSTEM PROPERTIES window choose the COMPUTER NAME tab.
Observe "Workgroup" name.
To change, click the CHANGE button
Put the new workgroup name in the WORKGROUP block
(WINXP default is MSHOME)
Click OK
Close all windows
You will need to restart PC to set the new workgroup
Nov 11, 2013 | Computers & Internet
How to hook up a hard drive from one computer to another
You need to connect the computer together in a network and then share the hard drive and or folders between eash computer.
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a router with several laptops and desktop PCs, which can access theInternet at the same time, then you have working network with the laptopand PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.
Jan 14, 2012 | Gateway DX441X Intel Desktop PC - Intel...
I am using server 2003 as file server wchich is in workgroup and connected to the network. problem is arising when any system from the network wants to access the shared folder the user unable to access...
Try this:
go to start>run and type: \\ server ip address
for example, if its 192.168.10.20, type \\192.168.10.20
Navigate to that shared folder, right click on it and create shortcut.
If the previous step doesnt work, go to server, unshare that folder, restart and share it again. Try accessing it.
Hope this helps
Aug 11, 2010 | Microsoft Computers & Internet
Windows Vista not accessing shared folders on network. It keeps asking to log onto network PC and keeps saying cannot log in when trying accounts on the network pc. Both PC's are on the same workgroup and...
This is a usuall problem when connecting Vista and XP, specially when your vista is a 64-bit and your XP is 32-bit. What you need to do is to manually map the folders on the vista by opening windows explorer and then clicking on Map network drive, you need to put in the exact folder location. Next thing is you need to add user not only activationg the allow access, you need to add the user on the shared folder, you are only using workgroups, unlike domain networks, you just have to give them permission.
Sep 05, 2009 | Computers & Internet
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
File Sharing
Here’s a very short summary of how to create a home network:
1) Create a named Workgroup (computer network name).
In Windows, the defaults are MSHOME or WORKGROUP, but you can choose your own
2) Add computers to the named Workgroup
3) Enable file and/or printer sharing.
Here are some resources to help you:
1. Windows XP has a wizard to walk you through it - see tutorial here
2. For Vista, try this link for a detailed overview: http://technet.microsoft.com/en-us/library/bb727037.aspx
These links might help too:
http://www.dummies.com/how-to/content/how-to-create-a-pc-network-workgroup.html
http://www.dummies.com/how-to/content/connect-to-and-share-files-with-other-pcs-on-your-.html
3. When it comes to sharing folders, there are two main ways to do this. You can either 1) right click the folder and enable sharing through the shortcut menu., or 2) add the file/folder to ‘Shared Documents’ (for XP) or ‘Public Folder’ (for Vista).
Hope this helps, but please come back to Fixya if you have any difficulties. Good luck!
Jan 25, 2009 | Belkin (F5D8231-4) Wireless Router...
I do have i mdb file on 1 pc and i need to shared wit 3 pc
First make sure all 3 PCs are on the same workgroup or domain. You can verify that in the System Properties, accessible by right-clicking the My Computer icon and selecting Properties, then selecting the Computer Name tab; below the Full Computer Name will be the domain or workgroup.
Once all 3 PCs are on the correct workgroup/domain, navigate to the folder where the file in question resides, and right-click the folder itself (not the file) and select Properties, and then the Sharing tab. From this tab you can select to share the folder, and set access restrictions if needed, and then the other 2 PCs should see the new share in their Network Places within a few minutes.
Dec 21, 2008 | Microsoft Office 2003 Basic Edition...
Password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Dec 02, 2008 | Microsoft Windows XP Professional
Home network
hi, 1) Check the status of the "computer browser" and "netlogon" 2) check the network configuration on both end IP=? Netmask=? Workgroup=? if these are not in same range make it same range any verify if pinging is happening. 3) Check if any firewall is causing the system, if firewall is exist try to open all ports for temporary to check. 4) go to control panel==> double click the network setup wizard==> "and follow the steps" remember that you are keeping same workgroup. 5)run antivirus and antispyware if any network threats are causing the problem if it didn't help you, write your OS version and applications name that have been installed on the system. thanks Arun
Aug 30, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
