MY ROPER WASHING MACHINE WON'T SPIN ALL THE TIME ESPECIALLY IF THERE ARE HEAVY CLOTHES IN IT
  • 254 Answers
You probably got a worn motor coupling, it's located between the motor and transmission.
Posted on Jul 15, 2008
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
Not spinning clothes enough. Have replace control element
You likely have an old or worn drive belt. When worn, the belt tends to slip, more than grab and won't spin the agitator adequately. This is especially common when the tub has a heavy load of clothes. The belt is most commonly located under the machine. Below is a video which shows the most common drive belt repair for most washers. Best of luck!
Greg
Dec 27, 2011 | Whirlpool Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Today my washer would not spin it will wash clothes thats it....I cannot locate my manual, not sure how old it is...it is a top load heavy duty
he lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is the part you need.
Here is a video to guide thru the process.
Nov 25, 2010 | Roper RAS6233KQ Top Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Washing machine wont spin
It broke the drive motor to transmission coupling go to www.repairclinic.com enter model number and look for this part. It's easy to change if you know a mechanically inclined individual.
Dec 23, 2008 | Roper RAS8445KQ Top Load Washer
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
