Question about Xante ScreenWriter (Refurbished) Laser Printer
Screenwriter 3 "paper out"
Started yesterday out of the blue, had been working fine earlier in the day- printer says "paper out", though paper is in tray. Tried turning off printer and unpluged it a few times but that hasn't worked...And on the printer list all the other printers are checked and decheckable, but the Screenwriter is checked but the printer itself on the list isnt decheckable or selectable. I thought maybe it got kicked off the server somehow, which runs through my computer, but it still reacts (lights up then goes back to ready/idle & paper out) when we try to print from any computer linked to it. Help!
Reinstall printer with a new name f ex X v7 (copy 1)
Posted on Oct 16, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xante Master
  • 1,362 Answers
Remove tray, is there a lever sensor there? is it freely movable ? in other words there is a loose piece of plastic which should be able to go up and down freely, check if it's stuck, is it broken, are the tires able to come down ( sometimes it is with the tire assembly).
Is the tray set to the correct size ? if you have letter in the tray but the stopper in the back is moved to Legal the paper has a gap in the front therefore the sensor does not read the paper.
These are the easiest things to check, can you make a copy in the By-pass? if yes the problem is only in the tray area.
It may be a bad sensor.
Posted on Jul 15, 2008
Xante screenwriter 5 jams & then prints wrinkled paper
Dear please clean the paper path it is some paper piece in it checked carefully,hope you understand.
thanks.
Apr 24, 2014 | Xante ScreenWriter 4 Laser Printer
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
I only get a black sheet of paper if I copy with my hp 1610
you will need to download the driver for leopard after you remove tiger
Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Black Streaks
pull drum unit out and clean corona wire by sliding blue plastic tab from side to side, making sure you put the tab back on the side that it was. if that doesn't take care of problem, then i would say you need a new drum unit.
razors
Jan 27, 2009 | Brother MFC-8440 All-In-One Laser Printer
Paper light on but printer has paper
Try reset using this procedure from Fixya past solutions:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and do not forget to rate this solution. Thanks
Jan 10, 2009 | Brother HL-2040 Laser Printer
Problem with my Screenwriter 4
With most laser printers whenever I see this problem It means that you had a paper jam but did not get all of it out. something is impeding the straight flow of the vellum. Most likely there is a piece of vellum stuck somewhere inside that you cant find.
Nov 04, 2008 | Xante ScreenWriter (Refurbished) Laser...
PSC 1215 - Not feeding paper
Hi
I think the problem is due to some paper picker inside the printer please show it to the service people near you location
T.Boopathy
Sep 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Major problem please help
i have had that problem for about 3 or 4 months and tonight i went inside and just started cleaning everything and my paper feeds right now. it was really weird. it just started working out of the blue.
Jan 23, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Xante ScreenWriter (Refurbished) Laser Printer Logo
184 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
