Question about Motorola Cell Phones
Cannot connect phone to PC. Software installed and updates downloaded but no luck. Phone is not locked. Help please!! Trish
I cannot connect my phone to the pc for music and videos transfer
Posted on Jul 15, 2008
Nokia E5 phone start-up failed. contact the retailer
the OS on your phone has crashed, that's why it is showing you start u failed.
Go to nokia.com, go to software and download nokia software updater. Download and install it on your computer. Connect the phone to your computer using a usb cord. Lunch the nokia software updater and it will install the phone, then another os will be download to the phone.
The phone should be okay, the moment the above is done.
Note that your computer must be connected to the internet when performing the above.
Also read and follow instruction on how to use the software updater on nokia site.
If the above does not work, it means you need another phone.
Good luck
Jun 22, 2012 | Nokia E5 Cell Phone
I CHARGED MY PHONE FOR 5 HOURS AND SINCE THEN THE PHONE JUST TURNS ON AND OFF WITH ONLY LG LOGO SHOWING WITHOUT BOOTING
Your phone OS is corrupt. Go to your phone manufacturer website, download software updater. Install it on your PC, connect the phone to PC using USB cord. Lunch the software, follow instruction and the process will flash your phone. The old files will be deleted and newer one would be installed.
Good luck.
Jan 06, 2012 | Cell Phones
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
Jun 16, 2011 | Nokia N73 Cellular Phone
My 3110c switches off iitself after 2-3 minutes everytime.I also changed the firmware but its not working.Plz anyone can help me.Plz give a solution for it!!!!!!!!!!!!!!!!!
Hi aaryandhunge....
If your phone is restarting you need to flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process.
Flash resets security code to 12345.
If your phone is switching of you need lock the battery correctly by putting a piece of paper.
or you need to change battery.
Thank you i hope tis helps feel free to ask queries.
Feb 16, 2011 | Nokia 3110 Cellular Phone
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
I have nokia5220 xpress music mobile,in that i am facing the problem of software corruption,i need to reinstall the nokia5220 system software,i want the software as well as the step how to proceed.please...
Installing the software on your Nokia device is fairly simple process. Please follow the steps below:
1. Download and install Nokia PC Suite from here: http://europe.nokia.com/support/download-software/pc-suites
2. Connect your Nokia mobile phone to your PC and backup the entire contents.
3. Download and install Nokia Software Updater from here: http://europe.nokia.com/support/download-software/device-software-update/news
4. Open the Nokia Software Updater and follow the on-screen prompts. The software will download and install the latest available software for your Nokia mobile phone.
Good Luck!
Dec 30, 2010 | Cell Phones
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
MY MOBILE NOKIA N73 IS DED
hi . there is a step by step procedure ..
requirement :- PC , internet , data cable , handset , charger .
step first download nokia software updater from link http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/download
after this install this software on your PC , after installing connect your fully charged phone to the PC and start this software ( internet must be in working condition ) , avoiding disconnection of any type ( light , cable , battery low ) it will take somewhere around 2 to 4 hours , but your phone will work that is for sure .
Mar 23, 2009 | Nokia N73 Cellular Phone
Cell Phones Logo
66 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
