Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e-Studio 207
Hey guys, I'm having a bit of trouble with installing the Toshiba e-Studio 207 digital copier. When I install it on a PC and share it out via GDI to a remote PC, the remote PC connect but can't even do a test print. Shows that the print does go through but without any joy actually seeing it come out. I checked all the security settings (Windows XP) and no firewall or any other security settings preventing it from happening. I reinstalled the drivers a couple of times but without any luck. The data light flashes when it receives the information from the PC but not printing it out. There's 3 other printers connected and shared out accross the network as well and they seem to work fine. Anyone got any ideas which I can try... I need someones help urgently ... thanks guys. Steph
  • 3 more comments
  • steph152 Jul 15, 2008
    There’s 2 PC’s connected on Ethernet through a rooter. Wow, you are fast on replying to a question… anything else you need to know?
    Thanks bud
    Thanks bud
  • Anonymous Apr 22, 2009
    Hey guys, I'm having a bit of trouble as well with installing the
    Toshibae-Studio 207 digital copier. When I install it on a PC and share
    it outvia GDI to a remote PC, the remote PC connects well and prints.
    when i share the printer over the LAN net work it installs well but
    when i print from a networked computer the remote pc that hosts the
    digital copier returns a Printer error: "Local device communications
    error" and No cassette with paper of the size requested is available,
    Click "Retry" to use paper from cassette 1 or "cancel" to abort print
    job". I checked all the security settings(Windows XP) and no firewall
    or any other security settings preventingit from happening. I
    needsomeones help urgently joshua
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the copier connected to the router as well?
  • Tim Babcock
    How is the remote PC connected to your network?
  • Toshiba Master
  • 2,794 Answers
That will do it.
Posted on Jul 16, 2008
Got it. There was a setting on the router which blocked remote users to share files. Changed a lot of settings and not sure which one actually allowed it but working fine now. Just remember to restart the pc after each setting 'cause the settings doesn't take immediate effect. Also try installing it on a different pc and make sure that all the firewalls are off as well as any other security settings set to low
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
How can i scan with Toshiba e-studio 207
Assumed that u connected the MFP to a PC using USB cable.
U need to have the viewer 2 cd, install the printer & scanner driver, follow by the P3 console application.
Oct 07, 2010 | Toshiba e-Studio 205 Copier
Toshiba e-studio 355 copier to a network şidresi 60 days later we know the password to Do
Hey guys, I bought a e-Studio 453 with that same problem, it has a trial period for printing. Can we remove the trial period without buying a kit? Can we just deactivate it or violate it?
Jun 25, 2010 | Toshiba e-Studio 350 Copier
Toshiba e-studio 207 "local device communication error
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Apr 22, 2009 | Toshiba e-Studio 232 Black and White...
Hi, I have one Toshiba e studio 200 that one is did not working as a printer now. Before that one was working. But yesterday i did the machine default setup. After that i did not getting the printer.
What kind of interface your estudio 200 is running ? GDI/parrallel cable or network?
If GDI, u need to make sure u installed the correct driver.
If network, make sure the IP address is static, network driver is installed properly.
Mar 28, 2009 | Toshiba Estudio 200L Copier
Toshiba Scanner E Studio 205
U can download the latest viewer at below:
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Everything is inside the application, just follow the instruction.
May 15, 2008 | Toshiba e-Studio 205 Copier
How to install scaner kit
The scanning features is built in with the MFP. What u need to do is connect to the MFP, install the viewer driver, u can start scanning...
Apr 25, 2008 | Toshiba e-Studio 205 Copier
Toshiba e-Studio 232 Black and White Copier Logo
504 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
