Question about Hotpoint Dishwashers
Hot point dishwasher model 7841a require part number for the main wiring loom from door to all main components
  • Anonymous Mar 22, 2014
    wired incorrectly and need to know solution
    President:
  • 1,462 Answers
Doubt this is available as a spare.
faults in the wiring loom where it flexes with the door opening are common
usual repair is to splice the broken wires
Posted on Jul 15, 2008
How do I fix a dishwasher
It sounds like you have a broken wire. You might also open up the dishwasher junction box (unplug the dishwasher first), and make sure the wire nuts are tight.
May 16, 2015 | Dishwashers
Neff dishwasher burning out controller
Sounds like water is getting into the main board. Either something is not tight or the gaskets are not firm around the door.
Feb 16, 2018 | Dishwashers
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
E3 SHOWING ON MY DISHWASHER .HOW DO I CHANGE ELEMENT OR SENCOR
E3 is heater related fault - either heater itself or the small thermostat right at the back in the middle of the machine screwed up into the base of the tub. This thermostat being open circuit is a common fault. Also check for the door loom chafing on the poorly finished lower panel where the wiring leaves the door into the base of the appliance.
Give me your model number to say how to change thermostat.
Oct 02, 2009 | Dishwashers
Unit does not turn on or intermitent
bottom of the door as the loom passes under the drip tray it catches rubs and then breaks around thsat area new door loom is available as spare part
good hunting
Mar 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
When on/off button de-selected large flash from top of door. Main consumer unit tripped and fuse in plug found ruptured. Fuse replaced cb reset but dishwasher has no power. Fuse rechecked found to be...
Dishwasher stripped down and found MAIN WIRING HARNESS chaffed agains door during opening and closing. New loom in region of £100 so repared old loom.
Aug 08, 2008 | Dishwashers
Need wiring diagram for a hotpoint df22 dishwasher on/off switch, the switch in it has been replaced with the wrong one so i have no reference to connect up the new one. thanks
You're in luck - I've just had one apart to repair the wiring loom.
The door switch is a simple two-pole latching switch with the wiring as follows.
This is the order of connections from the front.
1. Brown - Live (fed from mains)
2. Red - Load (goes to controller)
3. Black - Load Neutral (return from controller)
4. Blue - Neutral (goes back to mains)
By the way - the flat wiring loom gets fatigued at the bend at the bottom of the door and will eventually short out. Easy to fix with heatproof cable stripped out from an immersion lead.
Jul 05, 2008 | Dishwashers
Dishwasher not starting or emptying
bit difficult to diagnose this but worth while splitting the door and carefully examining the wiring loom where it goes round the corner at the bottom of the door. its quite common to get breakages at this point as it flexes every time you open or close the door
Mar 20, 2007 | Miele G880 Dishwasher
Dishwashers Logo
71 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
