Question about Char-Broil CharBroil 4637318 Grill
Propane in container but it turned off and now is not lighting. You need to make clear there is a charge from the beginning!!!!! This is misleading.
Gas regulator valve assembly char-broil end
Posted on Jul 20, 2008
Ran out of propane ..got propane filled but heater wont come on
It probably has air in the line. You need to be careful, but try to hold in the pilot button for a few seconds until you hear or smell gas. Then, turn it back off for a few minutes to let the air clear and try lighting it again.
Feb 24, 2015 | Water Heaters
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
Grill troubleshooting
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 15, 2014 | Weber Grilling
Procom propane heater will light the pilot but not the burner
the pilot and clean the injector and see if this is clear then try it , you will need a pressure gauge to check the gas pressure ,
Feb 03, 2010 | Heating & Cooling
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
The grill begins to heat up and stops. Only will
I believe you are out of propane. There is enough pressure to light the grill but as the liquid propane boils the temerature of the tank drops reducing pressure, and flame gose out.
Jul 18, 2009 | Weber Genesis Silver B Grill
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Low flame/ side burner dosen't light
I just read this online and it worked for me. Hope you have similar luck.
Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it.
Dec 02, 2007 | Weber Genesis Silver C Grill
Char-Broil CharBroil 4637318 Grill Logo
97 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
