Question about Panasonic Microwave Ovens
Have a Panasonic microwave model NN-6705A with a damaged door. Trying to locate a replacement door. Can you refer me to a source? Panasonic no longer supplies parts since oven was made in 1995
  • Tim martin
    Tim martin May 11, 2010
    Which part of the door do you need?
  • Panasonic Master
  • 9,098 Answers
You can order Panasonic parts here. Chances are you'll have to order just the part that's bad, assuming it's available.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer to see if they have any used or "new old stock" doors or parts.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
I have a Panasonic microwave NN-V689W where the door latch will no longer engage the microswitch. Where can I get a full parts list for this model?
You will need to check out from the Panasonic service centre ( try a search for this model) but the best will be to try to get a salvaged door assembly unit. Mostly many sets have their panel pads or electronic boards damaged leadding to scrapping the set. So if you can try you will be able to easily source all the reqired spares or the fully door assembly from a scrap dealer / repair shop. Also try to improvise with a latch for triggering the limit mocro switch. You can attach some plastic to be welded to the door latch so as to push the limit switch. at least for the time being or even use another limit switch with an extended stem. Hope you try this out. Good day .
Aug 11, 2010 | Panasonic Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic microwave oven
Microwave fuses are normally located either on a filter board near where the power cord comes in, behind the control panel between the door switches, or behind the control panel in a hodler, sometimes on the floor of the chassis.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find an authorized Panasonic servicer here.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 04, 2008 | Panasonic NN-H264 Microwave Oven
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya:
Nov 05, 2007 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
118 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
