Question about Hoover Washing Machines
The wash cycle runs and trhe water does not drain and there is no spoin cycle. Can you tell me what the problem might be. Hoover Ultraclean 1100
    President:
  • 1,462 Answers
No drain then no spin.
check filter and check for a foreign object stuck in drain pump impellor
Posted on Jul 15, 2008
How do I drain a Hoover performsance 1100
Take a look at these Youtube videos on how to drain it. It depends on what is stopping it from draining...either bad drain valve, defective circuitboard..., bad pump etc. But to just to get the water out so you can move it or service it bu these videos might help:
https://www.youtube.com/results?search_query=how+to+drain+a+washing+machine
Feb 25, 2015 | Hoover Washing Machines
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
How to work the hoover performa 1100 washer dryer
My Hoover Performa 1100 does not drain the water therefore it does not open. Can anyone help please?
May 15, 2009 | Washing Machines
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help...
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Nov 22, 2008 | Hoover Washing Machines
Hoover performa 1100 ac110
hi,
unplug it
try and take the drain hose out of the wall drain and get it as near to the floor as possible into a bucket, maybe let it hang out the door on the ground, gravity should let the water drain out, If its a new type it may not work though but you can try that.
good luck
J
Jul 16, 2008 | Washing Machines
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
