Question about LG Dryers
Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running.
Its a hotpoint ultima TCD970 dryer
Posted on Mar 03, 2014
  • 525 Answers
Your complaint is;"Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running".
You have not provided a brand name or model number. I I can only offer information based on genric or common solutions. Below is a link that should prove helpful if you need additional information.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 15, 2008
  • Katherine Langham Mar 03, 2014
    its a hotpoint ultima TCD970 dryer
Noisy dryer
I have had the same problem in the past, one thing you can check is the drum. See if it has any play by opening the door and see if you can push it up. it could be the felt strip is worn down or the rollers if it has any or the main bearing in the back. It is posible that is is one of the three things I said because they all cause noise. check it out i hope it helps you.
Feb 09, 2014 | Zanussi TD4112W Electric Dryer
Dryer rotation is noisy for first 4 or 5 mins then is quiet for balance of cycle.
the tensioner pulleys bearing is dried up so replace that and the drums belt too
it will eventually break very soon
Jun 16, 2010 | Estate TEDS840JQ Electric Dryer
Bosch dishwasher noisy vibration
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool gold quiet partner iii bearing noise
if its noisy when washing check chopper assembly. if its ok change the sump pump assembly
Feb 09, 2010 | Whirlpool Dishwashers
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryers Logo
160 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
