Question about Sony 36IN TV Stand Designed for Model KV-36FS120
Upconversion to 1080i playback
I have just been given a 40 inch HDtv that is capable of reproducing 1080i. I want to purchase a DVD player that will upconvert to a 1080i picture. The one thing I'm not sure about is that the TV only has component video input or S-video input. From what I've read, the component video (3 cables) are better than S-video. Most of the new upconversion DVD players have HDMI and component video output. What I'm wondering is how to determine if the upconverted signal will be sent thru the component video. I've looked at all the upconversion DVD players and they are not specific on that matter, some descriptions lead me to think the upconverted picture is only sent out via the HDMI cable.
I'm leaning toward the Sony Model: DVPNS700H/B
  • smittybd Jul 15, 2008
    Great info, I'll go to the different manufactuer's and do some research. Thanks,
    Smitty
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 15, 2008
How to plug a blu-ray dvd in my theaterwide tv...i have a hdmi converter to componant but no images.....thanks
Your TV cannot reproduce 1080p resolution so go into the menu setup of bluray player and make sure resolution is on 1080i and not 1080p. I understand you will have to do this on another TV capable of 1080p or if your bluray player has a composite output (yellow single rca) then hook that up as it may be active at the same time into your AV in on the TV. Once you have picture, then you can enter the setup menu as I have indicated above. I hope this solves your problem.
Jul 02, 2016 | Toshiba TheaterWide 52HM84 52" Rear...
I know dvd player can not play Blu-ray but is not the Samsung dvd hd870 different. It reads 1080i.
That refers to the video output - your player is capable of upscaling: it transforms, without changing the quality of the image itself, the resolution from SD (480i) to HD (1080i).
Jan 28, 2011 | Samsung DVD-HD850 DVD Player
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Jan 13, 2009 | Toshiba SD-K860 DVD Player
Receivers
If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for Onkyo at this level. From Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via HDMI. Onkyo's own RIHD (Remote Interactive over HDMI) also gives you inter-operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this levelSpecial Features
  • HDMI v1.3a Repeater (4 inputs, 1080P compatible)
  • HDMI Video Upconversion
  • 1080i Upscaling powered by Faroudja DCDi Edge
  • TrueHD, DTS-HD Decoding
Amplifier
  • # Channels 7
  • Power (8ohms 20-20kHz 0.08%) /Ch 90W
  • Power (8ohms 1kHz 0.7%) /Ch 105W
  • Continuous 6ohms Rated
  • High Instantaneous Current Capability 36A
  • Amplifier Frequency Response 5Hz-100kHz
  • S/N Ratio (LINE IN) 106dB
  • All Discrete Circuitry
  • Absolute Ground Plate
  • Optimum Gain Volume
  • Non-Scaling Configuration
  • Bi-amp Capability For Front
Processing
  • DOLBY Decoder DD Plus, TrueHD
  • DTS Decoder DTS-HD Master Audio
  • Direct Mode
  • Music Optimizer
  • Audyssey Dynamic EQ
  • 192K/24 Bit DACs
  • DSP Type / QTY 32 BIT
  • Adjustable Crossover 40/50/60/80/100/120/150/200Hz
  • Independent Crossover
  • AV Sync
  • Accurate Speaker Distance Setting
  • Multi-Band Speaker EQ 5 Band
Connectivity
  • Audio In/Out 7 / 2
  • Digital Audio IN (OPT/COAX) 2 / 2
  • Composite In/Out 5 / 1
  • S-Video In/Out 4 / 1
  • Front-Panel A/V L / R / V
  • Component Video / Bandwidth 2 in / 1 out / 50MHz
  • HDMI In/Out 4 / 1
  • HDMI Version V1.3a Repeater
  • HDMI Bandwidth 1080p
  • HDMI Deep Color Capable (36bit)
  • Analog to HDMI Upconversion
  • 480i to 480p Processing (DCDi Edge)
  • 1080i Upscaling
  • Multi-Channel Input 7.1
  • Surround Pre-Outs SUB
  • Powered Zone2
  • Zone 2 Line Out
  • iPod Ready (DS-A2x, DS-A2, DS-A1)
  • SIRIUS Radio Ready
Integration Access
  • Onkyo-RI System Control
Miscellaneous
  • Pre-Programmed Remote
  • Glossy Black finished Remote
  • Simple Remote to change input & mode
  • Color-Coded Speaker Terminals
  • Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
  • On Screen Display Out
  • Permanent Memory Storage
  • Solid Aluminum Front
  • Warranty 2 YEARS
Oct 13, 2008 | Audio Players & Recorders
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
