Have a peavey-xr-600b peavey mixer amp. i get aloud hum and noise and cracking when plugging speaker jacks.
  • 1,512 Answers
Hi chillin884
Not a good sign. Something has gone wrong with the output stages of your Peavey. It is not a good idea to continue plugging it in as damage may occur to your speakers. I suggest you take it to a decent music gear repair guy for a look see and give you a quote to repair These heads, like all Peavey gear, are pretty solid and worth repair. Sorry to be the bearer of bad news like this, good luck
regards
Graeme
Posted on Jul 15, 2008
Can I connect my peavey 600b amp to aux or to my existing hifi
If you connect the Main 1/4" out on the front to you HiFi aux input it should work. You will need to play with the volume controls to set the proper level so as not to overload the aux buss. The XR-600B manual is here-
Peavey XR 600B Operating Manual Page 4
Mar 01, 2015 | Peavey Music
Hi , i need a service manual for the peavey xr 8600 powered mixer . Not the xr 8600D . THANKS
http://music.manualsonline.com/manuals/mfg/peavey_electronics/powered_mixers_model_xr_8300_xr_8600.html
Dec 07, 2014 | Peavey Audio Players & Recorders
Peavey XR 122D powered mixer developing hum noise dispite pressing the noise filter. anything more to be worth doing?
I need a bit more information but from what i can tell it's about the power supply capacitors issue, as this devices are known to develop such kind of humming annoying noise when they go under the specified value, let me know further,
Regards.
Jul 20, 2014 | Peavey XR 1220 Powered Mixer Mixer Powered
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
Jun 18, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Jul 25, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
I have a Peavey XR- 600 Mixer amp. That has a hum
you need to clean the line out jacks and the effects jacks and all the master jacks with a freon based cleanef that is safe for plastics... Ues a 1/4 inch cable plug in and out repeatedly while the power is off..
There is an intermittan crossion of the switching jacks in the master secrion...
Mar 14, 2009 | Audio Players & Recorders
512 people viewed this question
 Grubhead
Grubhead
