Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
New geforce 9500gt video not working on my windows xp emachines c6423. I uninstalled original drivers and disabled onboard nividia 6100 through device manager and bios. Then loaded new 9500 GT drivers but still get no pic with new card even after restart and several redos. Keeps defaulting to old card. Is it not compatible and if not which nvidia card should I get?
4 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: PCI video card not working in XP, T1090 emachine
Have you disabled the on-board video, if not you will have a conflict between the 2
Posted on Feb 18, 2009
  • 9 Answers
SOURCE: Need windows XP drivers for eMachines t3616
google: nvidia nforce network management. This will take you to
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
You can then download the driver for you network adaptor which will then get you into the internet where all things are possible!
Posted on Oct 12, 2009
SOURCE: I would like to upgrade my emachines t6528 pc with
First you need to make sure that motherboard has a PCI-Express slot
If it has that then you will be able to upgrade to any card you want willing your power supply has enough wattage to fuel the card
Most higher end video cards need 450W power supply's to operate without problems
If you meet both of those requirements then your good to go :)
Posted on Dec 26, 2009
Hi I tried to install a PNY GeForce 9500gt into my HP pavillion PC with a NAPA MCP73M01H1 motherboard. The Mobo has GeForce 7100/nForce630i Chipset. For some odd reason The Geforce 9500gt would not show up...
this appears to be related in the BIOS. try to update the BIOS and disable the onboard video card from there if an option is available, then install the video card again and install the latest video driver for it compatible with your operating system
Jan 30, 2011 | PNY Technologies nForce 630i / GeForce...
How to install xfx GeForce 9500GT on Intel D915GAG motherboard
Start the pc and uninstall the video driver for Intel 915G, shutdown the pc, plug the new card in the PCI-E 16x connector and connect the monitor to it, boot into BIOS and disable the onboard video, boot normally and go to nVidia site and download the latest driver, install the nVidia driver.
Jul 11, 2010 | Intel D915GAG Motherboard
Can emachine t3646 be down graded to windows xp
yes of course it able to use theh latest version so it is also capable of using sindows XP...since it both a microsoft product....
format your unit and install a fresh copy of windows xp...
Oct 19, 2009 | eMachines T3646 Refurbished AMD Desktop...
Needs drivers
Under downloads section: http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=C%20Series&model=C6423
Next time you have any trouble downloading drivers, please go to the manufacture's website.
Apr 29, 2009 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Graphics not displaying properly
Yes left click on start, right click on computer, left click on properties, left click on hardware/device manager, click on the plus sign next to display adapters, select nividia 6100, right click on it, left click on properties, you can choose any of the items, roll back, update, or uninstall. Warning, if you do not have another video output this will cause you to not see anything.
Dec 03, 2008 | E-Machines eMachines Desktop PC
Video Card Upgrade Problems
Does this computer have an onboard video card?
If so you will need to disable this feature in the system BIOS.
It should be under onboard devices.
You will need to use the onboard card to enter the system bios and then turn off the onboard card. install the new card and then connect the monitor to it then power on the machine
Nov 30, 2008 | E-Machines eMachines Desktop PC
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Dave
Nov 11, 2008 | ASUS M2N-MX Motherboard
I'm trying to install a new graphics card Verto Geforce 9600 GT. When i run the CD i get a setup error saying The NVIDIA setup program could not locate any drivers that are compatible with your current...
Disable the existing video card in device manager and try again. The onboard video will always try to take first spot, so disable it ...your video will still work until you can install the new video card :)
Hope this helps :)
Sep 28, 2008 | Computers & Internet
Ethernet drivers
Most drivers can be found at Drivers.com.
Jun 17, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
